Stuck rear seat in 94 civic hatch?
The rear driver seat can not go down because the latch is broken. Pops right off.
I've tried jimmying it with a screwdriver, no luck.
What should I do?
Thanks.
What should I do?
Thanks.
Are you referring to the bottom portion? That part has metal tabs on the bottom that inserts into slots of the frame. At the rear section, it is held down with a 10mm bolt...found in the middle above the fuel pump location.
Sinner
Jan 16, 2006 07:22 PM
