Nubworks custom A2W IC piping, Linder Power System couplers
Old Mar 11, 2012 | 07:15 AM
cartunescivic's Avatar
Default Nubworks custom A2W IC piping, Linder Power System couplers
so, Justin came down to Speeding-G60 Race Team HQ today and we spent the whole day redoing the entire boost piping, utilizing Linder Power Systems custom couplers.
we welded onto the turbo compressor outlet, the A2W intercooler inlet and outlet, even cut off and welded on to the throttle body.
it was a longish day of fabrication and welding, and it looks kick ***. i had a MESS of little horseshoe shaped niblets of aluminum pipe laying around when i was done from the constant nibbles and cuts, etc. and Derek showed up three or four different times throughout the day to avail himself of a TIG machine and offer thoughts on the days proceedings. all inputs are welcome and give extra views when stuff like this happens.
THANKS JUSTIN!!!!!
had a fat 3 lb Rib-Eye lunch and beers along the way. when welder comes to you, then feed him you must!
and now to push this even further into the 9's with the new BW S400sx 67mm Billet FMW.... last dyno (63mm BEP turbo) was 737Awhp and 568 wtq @ 40psi.
and this is the coupler and how it works....
Old Mar 11, 2012 | 07:30 AM
89efhatchy's Avatar
Default Re: Nubworks custom A2W IC piping, Linder Power System couplers
Hmm those are pretty neat, just sucks that if one were to have an issue the pipe would have to be cut to get the ring off. What kind of car is this? Everything looks nice.
Old Mar 11, 2012 | 09:38 AM
paulzy's Avatar
is there any give to them or are they solid like vbands?
They look easier to fasten than wiggins and van jens though
Old Mar 11, 2012 | 09:48 AM
they have play in them, and are NOT solid like a v-band.
and this car is an Audi Coupe Quattro, fastest/quickest Quattro (AWD) 4cyl in N America.
http://www.linderpowersystems.com/in...?go=news&id=44
Originally Posted by Linder Power Systems
Are you tired of blowing off intercooler pipes? Or paying too much for the purple brand?
We have the solution!
3" and 4" Aluminum Intercooler Couplers are a weld on design and are capable of holding pressures in excess of 150psi! Thats alot of boost! These couplers are manufactured out of aircraft grade aluminun and have an easy thread together design that allows up to 5 degrees of flex without a leak and without failure!
Available in Raw Silver or Anodized Black
and, they are rated to hold 150 psi, as well.
http://www.streetfire.net/video/lind...ers_103574.htm
Old Mar 11, 2012 | 10:39 AM
reaction360's Avatar
I've been running the Linder couplers for 3 years now without a single issue. I have them from the turbo all the way to the Throttle body. I'm running an S372R at 45+psi consitently.
Old Mar 11, 2012 | 07:52 PM
Divers's Avatar
Aaron, there's this crazy invention called a mandrel bend that bends around things without a million pie cuts. I can send you a link
Looks good though. You gonna tnt next weekend?
Old Mar 11, 2012 | 09:24 PM
yaya. funny thing. i ordered a 45 and a 90 mandrel bends, in 11 ga. charged out my *** and waited three weeks to end up receiving 16-18 ga parts. was pissed off!
so i took a long radius sweep i had and made it work. the cuts were only ~80% of the pipe. it was a hard double plane dual 45 plus S-curve too, in a very short distance. its cool and its done.
mine isnt done yet, still waiting on a few things plus a new window net. i wont be coming for the opener up there.
Old Mar 11, 2012 | 09:32 PM
SovXietday's Avatar
Hahaha, these were my thoughts as well.
Fab work looks great though, sucks about the order. Would have probably looked nicer with bends vs pie cutting.
Old Mar 12, 2012 | 09:44 AM
Divers's Avatar
What's wrong with 16ga? Columbia river mandrel bending is in Portland I think. And that have same-day will call. Just a heads up if you need bends in the future and don't want to wait for shipping.
Old Mar 12, 2012 | 03:27 PM
oh i know of them, and they are close enough to run out and get them. i have been out that way before.... its actually about 1/2 hr West, in St Helens. last time i was out there i was getting some SS 1.5" and 1.25" tube and bends.... for radiator / coolant piping stuff.
funnier yet, i have 45 and 90 in the lighter gauge stuff already here. thats the salt in the wound the place i ordered from made LOL.
its all good, its done and getting some of the welders plates welded on.
b20vcrxsir
Feb 8, 2009 04:38 PM
hb_guy
Jul 9, 2007 06:21 PM
MayhemSi
May 7, 2004 06:49 PM
mattcalica
Jul 19, 2003 07:37 AM
