91 si ls axel swap question
i have a 91 hatchback si that im trying to do a ls swap, i was wondering what type of axles do i buy so they would work. also the ls that im using had a auto transmission. could i use that half shaft thats there?
thanks
thanks
get them from a da integra im not too sure but i believe 90 91 da axles are shorter and will work best the later da integras 92 93 are longer and are not recommended not tooo sure but i heard all da's would work google it make sure the spline count is the same also on any trans thats why you want to buy axle for same year trans too clear up an confusion
when i was going to put in my ls, the motor was from a newer obd1 teg, and the trans was an older cable one. I was told from the person i bought it from to look up the trans code and get the axles that it originally had.
I'm an old dumb guy compared to a lot of you guys. And that said I guess I'm smarter since all I did was type "Ls swap into crx" on google and guess what!?! Tons of info!!
But here, since you lazy spoon fed babys like being pampered here is an answer
Axle half shaft da integra 91. rear upside down L engine mount bracket is also needed 89-90 da integra. Axles 91 DA
bigwilly1878
Jan 31, 2007 06:51 PM
JokerTypeR
32
Oct 10, 2006 05:08 AM
