Once again, i've encountered the mysteries of the Check Engine Light.
Old Oct 10, 2002 | 01:46 PM
DeeperFOLK's Avatar
Default Once again, i've encountered the mysteries of the Check Engine Light.
A few days ago, while i was out cruising i accidently floored the gas pedal. Yes, it was an accident. It made the loudest growl i've ever heard, but it sounded healthy. About 1 minute later the "check engine" light came on, and it made me a bit nervous, thinking I may have damaged something while (accidentl) flooring my gas. Everything seemed to run fine, actually it seems that it runs better if you can believe that. I was convinced there was nothing wrong, so i reset the computer. Everything was fine as it's always been, but i sped up pretty fast again today to take on another Accord, but i did not floor it. The check engine light came back on after this today.
My question... Could I have caused damage to something by doing this? The car runs exactly the same with no noticable differences. Has anyone else had the "check engine" light appear after doing something like i have done? I'm really low on cash since i'm moving to Orlando in 2 weeks, and i'd rather not bring it into the shop just to see what's wrong. If anyone could give me their experiences or maybe alittle insight, that'd be great.
Old Oct 10, 2002 | 02:49 PM
niedejb's Avatar
Default Re: Once again, i've encountered the mysteries of the Check Engine Light. (DeeperFOLK)
What year? trim?
Where are you in IL?
Try here for info....
http://home.insightbb.com/~niedejb/refs2.html
Old Oct 10, 2002 | 04:30 PM
Chiovnidca's Avatar
Knowing what code is stored would be a plus. It might point you towards the problem.
Old Oct 10, 2002 | 05:05 PM
DeeperFOLK's Avatar
Default Re: Once again, i've encountered the mysteries of the Check Engine Light. (Chiovnidca)
hey... It's a 96 accord EX. Would these readings for the 97 that you linked me to, still be relevant?
Old Oct 10, 2002 | 05:06 PM
DeeperFOLK's Avatar
Default Re: Once again, i've encountered the mysteries of the Check Engine Light. (niedejb)
ah yes.. I'm from Naperville! Forgot to add that.
Old Oct 10, 2002 | 05:07 PM
niedejb's Avatar
Should be the same...I think the 98's + have different codes.
Too far for me to help out.
[Modified by niedejb, 8:08 PM 10/10/2002]
Old Oct 10, 2002 | 05:23 PM
DeeperFOLK's Avatar
niedejb, i'm looking at your site and it seems that the blue connecter in my car only has one plug hooked into it. So there is no way for me to check. That's kinda weird. I've only owned this car for 2 months now, and i'm starting to learn that the guy who owned it before me did some strange things to this car.
Is there by chance another way to check?
Old Oct 10, 2002 | 05:25 PM
niedejb's Avatar
The plug may be connected to a big (blue) plastic male piece.
Should be the only plug with two wires that dont go to anything else.
Old Oct 10, 2002 | 05:37 PM
DeeperFOLK's Avatar
I found the big blue plastic peice... But there was only one wire going in it. It seems there could be 2?
I"m no car expert...
[Modified by DeeperFOLK, 2:38 AM 10/11/2002]
Old Oct 10, 2002 | 06:25 PM
niedejb's Avatar
Get it taken care of?
Old Oct 11, 2002 | 09:39 AM
DeeperFOLK's Avatar
Niedejb! I thank you for your patience and help. I got it sorted out and the light is now gone. Hasn't returned yet, and after resetting the ECU it seems it likes me a lot more. Thanks again. Now i know how to check the "check engine" problems now, very cool.
Old Oct 11, 2002 | 01:28 PM
Chiovnidca's Avatar
What code was it?
Old Oct 11, 2002 | 01:36 PM
niedejb's Avatar
9 Cyl postion sensor malfunction.
My brothers lude flashed this once and he reset it never to see it again.
aspire
Jun 28, 2010 10:49 AM
angryk
Honda Civic (2001 - 2005)
Dec 28, 2007 11:53 AM
97exd16
Apr 10, 2006 08:40 PM
jsardo
Jun 11, 2005 08:11 AM
B18Redline
Apr 7, 2004 08:01 AM
