Simple tire size question
Am I correct that if I use a taller tire, then, it should take me a little bit longer to go through the gears?
The reason I ask is b/c I was hitting the rev-limiter in fourth gear at the end of the quarter mile when using my 22" slicks.
I have a new set of 23" tires and was hoping it doesn't change in that I would need to shift into fifth.
BTW D series, Si trans.
That is correct. Try playing with some of the gear calculators out there and you can see how it effects mph through the gears.
teammfactory, zealautoworks, etc. have calculators.
