Simple tire size question
Old Mar 10, 2012 | 09:44 AM
1991civicsi's Avatar
Default Simple tire size question
Am I correct that if I use a taller tire, then, it should take me a little bit longer to go through the gears?
The reason I ask is b/c I was hitting the rev-limiter in fourth gear at the end of the quarter mile when using my 22" slicks.
I have a new set of 23" tires and was hoping it doesn't change in that I would need to shift into fifth.
BTW D series, Si trans.
Old Mar 10, 2012 | 09:50 AM
Blown90hatcH's Avatar
Default Re: Simple tire size question
That is correct. Try playing with some of the gear calculators out there and you can see how it effects mph through the gears.
teammfactory, zealautoworks, etc. have calculators.
Old Mar 10, 2012 | 09:54 AM
Project_EK's Avatar
Yes you are correct. You will pass the traps at a lower RPM in 4th w/ the 23's.
Old Mar 10, 2012 | 09:57 AM
Good, thanks!
MoiMotorsports
Aug 3, 2010 04:46 PM
kun3racer
Jul 26, 2004 06:37 PM
