obd0 cel 43 code b18a1
Old Mar 9, 2012 | 09:33 PM
todubbled1's Avatar
Default obd0 cel 43 code b18a1
Car runs horribly at take off seems to sputter fuel. Smells rich. On a hill it tends to not want to crank. Any opinions would be highly appreciated. Changed out fuel filter and plugs are all good along with wires new dizzy and a new o2 sensor.
Old Mar 9, 2012 | 10:21 PM
bradley's Avatar
Default Re: obd0 cel 43 code b18a1
OBD0 shouldn't throw code 43, it wasn't implemented until OBD1.
How are you counting the CEL?
Old Mar 9, 2012 | 11:01 PM
90civic-ZC's Avatar
Are you sure it's not 4 and 3?
Old Mar 10, 2012 | 01:47 AM
bradley's Avatar
ZC is right, sounds like code 4 and 3. Which would be MAP. And your symptoms sound correct.
Old Mar 10, 2012 | 07:05 AM
90civic-ZC's Avatar
^ exactly
Old Mar 10, 2012 | 09:11 AM
todubbled1's Avatar
nope its obd0 pr4 4 paused blinks then three upon the 4 pauses right after not two different.
Old Mar 10, 2012 | 09:12 AM
todubbled1's Avatar
well my buddies car just had a bad map and his ran nowhere near like mine replaced it all is good now.
Old Mar 10, 2012 | 01:01 PM
90civic-ZC's Avatar
OBD0 ecu's have single blinks....there's no multiplying by ten or anything.....if there's 4 blinks that's code 4, three more after that is code 3.
Old Mar 10, 2012 | 06:56 PM
todubbled1's Avatar
1 O2A - Oxygen sensor #1
2 O2B - Oxygen sensor #2
3 MAP - manifold absolute pressure sensor
4 CKP - crank position sensor
5 MAP - manifold absolute pressure sensor
6 ECT - water temperatu re sensor
7 TPS - throttle position sensor
8 TDC - top dead centre sensor
9 CYP - cylinder sensor
10 IAT - intake air temperatu re sensor
12 EGR - exhaust gas recircula tion lift valve
13 BARO - atmospher ic pressure sensor
14 IAC (EACV) - idle air control valve
15 Ignition output signal
16 Fuel injectors
17 VSS - speed sensor
19 Automatic transmiss ion lockup control valve
20 Electrica l load detector
21 VTEC spool solenoid valve
22 VTEC pressure valve
23 Knock sensor
30 Automatic transmiss ion A signal
31 Automatic transmiss ion B signal
36 traction control found on JDM ecu's
41 Primary oxygen sensor heater
43 Fuel supply system
45 Fuel system too rich or lean
48 LAF - lean air fuel sensor
54 CKF - crank fluctuati on sensor
58 TDC sensor #2
61 Primary oxygen sensor
63 Secondary oxygen sensor circuit
65 Secondary oxygen sensor heater wire (black wires)
67 Cat Converter
71 random misfire cylinder 1
72 random misfire cylinder 2
73 random misfire cylinder 3
74 random misfire cylinder 4
80 EGR Valve/Line
86 ECT sensor - Cooling System
91 Fuel Tank pressure sensor
92 EVAP Solenoid/Valve/Vacuum Lines
Old Mar 11, 2012 | 01:36 AM
ef yu's Avatar
so much wrong information .....
Old Mar 11, 2012 | 12:05 PM
bradley's Avatar
Code 43 is only thrown by OBD1 ECUs, and is exclusive to the Civic/Del Sol/Accord/Prelude platforms, Integra ECU throwing code 43 even being OBD1 would theoretically be impossible.
There is NO OBD0 code 43. OBD0 has no codes past 20.
For clarification:
Code 43
Accord 90-95
Civic 92-95
CRV n/a
CRX n/a
Del Sol 93-95
Odyssey 95
Prelude 90-95
Fuel Supply System
defective or malfunctioning fuel supply system
Old Mar 11, 2012 | 05:44 PM
todubbled1's Avatar
Well put new ecu in less stuttering no solid blinks and three anymore only code 9. It is a new dizzy guess I need another one.
Old Mar 11, 2012 | 05:58 PM
90civic-ZC's Avatar
code 9 is for your timing.....is you're mechanical timing correct?
Old Mar 11, 2012 | 09:01 PM
todubbled1's Avatar
Yep tdc timing marks all line up
Old Mar 11, 2012 | 09:02 PM
todubbled1's Avatar
Cyp sensor choice is within the dizzy I thought?
Old Mar 11, 2012 | 09:59 PM
ef yu's Avatar
For clarification:
Code 43
Accord 90-95
Civic 92-95
CRV n/a
CRX n/a
Del Sol 93-95
Odyssey 95
Prelude 90-95
Fuel Supply System
if OBD0 doesnt have a code 43 then how did i get this?
btw, what you listed was a HONDA category. If you had looked at a Acura section (b18a1) you would find it.
So many wrong information has gone through honda-tech and into others car.
DONT THINK, KNOW.
Old Mar 11, 2012 | 10:22 PM
crx_si-r's Avatar
I was gonna say, I had a code 43 before when I fist swapped in an LS in my crx years ago. Turned out I had an open in the wiring for the fuel pump under the storage thing
Old Mar 12, 2012 | 04:48 AM
90civic-ZC's Avatar
Yeah cyp is in the dizzy except for OBD0 DOHC ZC's
Old Mar 12, 2012 | 04:53 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
This has been covered extensively many times before... It really helps to search...
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/unexplained-codes-3014835/
Also, LOL at no code 43 on Acuras or OBD-0. "Bradley", you post a lot of misinformation quite often.
Old Mar 12, 2012 | 02:37 PM
todubbled1's Avatar
It was funny had code 9 on my old dohc zc obd0 and it was my dizzy
Old Mar 12, 2012 | 02:46 PM
90civic-ZC's Avatar
I'm sorry, you're right I'm wrong....I must've read it wrong earlier today. It's the CPS that's on the exhaust cam.
Old Mar 12, 2012 | 07:28 PM
todubbled1's Avatar
Correct sir
Old Mar 17, 2012 | 11:04 PM
bradley's Avatar
https://honda-tech.com/forums/showthread.php?t=3014835
I never post incorrect information, I simply didn't know there was a code 43 on OBD0, had never seen it nor heard about it before. I did some searching and most people rule it out to be the FPR taking a crap on them *shrug* but it appears to happen RARELY.
This is the only time I recall "posting incorrect information". You need to quit calling someone out for something when you don't know them very well.
There is a reason he posted it here -- to get everyone's opinion, not just mine. That's why forums have hundreds of users.
Old Mar 19, 2012 | 01:00 PM
DO IT ON ALL FOURS
Oh? Then what is this? You do this quite often.
That's the problem, your information comes from reading other misinformation. Thanks for confirming that.
If you REALLY need me to show you I can.
This is EXACTLY how misinformation is spread. Forums can be great, but when people like you contribute it makes them useless.
Have fun!
Old Mar 26, 2012 | 06:10 PM
builthatch's Avatar
MiG-21 superfan
Have fun!
stop antagonizing people. if you have a problem, correct the info and move on. if it's a personal problem with his posting habits, PM him and/or be prepared to prove what you are accusing him of because he is disputing your claims.
thanks.
