Doing a new project...have some questons on vtec-e
Old Mar 9, 2012 | 12:37 AM
metalslug's Avatar
Default Doing a new project...have some questons on vtec-e
So now that my father found out I am into civics he wants to teach me how to build one. I want to basically make a VX, I have access to a low miles vtec -e and tranny. Now here are my questions:
* I cant find the harness for it, I think I can use the EX harness not sure (would a CDM VX harness be any good to me?). I know it has the EGR box I cant find that either, I live in NY and I'm not sure if I need it for emissions and if I dont would it run fine w/o box?
* Which ECU to use?
*I want an EG shell, but is there any particular shell that may favor the build? DX, CX?
*My father wants to convert my auto DX (currently has a 95 EX engine. I get around 32-34mpg but with 68 miles of hwy one way i need more mpg) into manual but I think that would be just to expensive, rather buy a rolling manual shell/hatch and swap engines, am I correct?
Any help would be appreciated. Thanks.
Old Mar 9, 2012 | 04:59 AM
kp's Avatar
kp
Default Re: Doing a new project...have some questons on vtec-e
So you're saying you have an engine/tranny and you need a shell to put it in? And you're also saying that you currently get 32-34 mpg and you "need more"?
You need to find a complete VX shell, simple. Sourcing all of these parts and completing this swap properly will prove to be a royal pain in the ****. It will never run correctly and will have all sorts of wierd issues.
I suggest rebuilding the engine/tranny you have and dropping it into an actual VX chassis when you find one. Take your time, be patient and have fun. Keep your current 34mpg DD and be happy with that fuel economy.
Old Mar 9, 2012 | 06:39 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
* Which ECU to use?
Any eg shell will work and the difficulty will be about the same. A manual swap isn't that pricey, it just is going to be a little work. You can find everything for a manual swap in the junkyard. I would just convert the tranny since you already have the car. You should be able to use your EX harness and just have to wire in a few things that the VX has. A CDM VX harness would work.I have everything you need for the VX. I just took mine out for a gsr swap. PM sent
Old Mar 9, 2012 | 06:00 PM
metalslug's Avatar
PM replied. The engine I found is a JDM Vx, with the tranny and all engine components, about 25-35k miles on it. its a little over 850 USD, fair price?
Euro-R82005
Oct 15, 2015 05:43 AM
CRXguy_88
Dec 8, 2013 01:17 PM
beef-cake
10
May 9, 2006 05:22 PM
vtec25
Jun 14, 2005 06:32 AM
EDEN'S97HCHB
Mar 24, 2004 03:36 AM
