b16a2 acting up near vtec
Old Mar 8, 2012 | 03:57 PM
c5stunna's Avatar
Default b16a2 acting up near vtec
So I had a healthy b16 in my ek. Bought a head an had Sk2 springs an retainers put in along with stage 2 blox cams off Craigslist.
Installed the head got it running went on a test drive babied it for like 30 miles then went to hit vtec with the throttle to the floor an it starts cutting out. Vtec engages but it sputters an sounds horrible.. it feels strong before 4k and its torquy it went up a hill near my house in 5th as usual so its not unusual their. I've tried different ecu's I reused my dizzy vtec solinoid an injectors.
Any ideas? Timings on and no cel's or anything... I'm stumped tried adjusting the timing. An double check every plug. Its killing me haha
Old Mar 8, 2012 | 04:56 PM
c5stunna's Avatar
Default Re: b16a2 acting up near vtec
Any ideas anyone?? Any suggestions will help!
Old Mar 8, 2012 | 04:58 PM
eg6 type-R's Avatar
u need a DYNO TUNE with anything bigger than a stock camshaft
Old Mar 8, 2012 | 05:08 PM
iwannarace's Avatar
I've got the same issue. I've been researching and there are several examples of folks who swapped in new cams, had this issue, tried different things to remedy it and then decided to replace the aftermarket cams for oem's and have everything return to normal.
after I replaced my cams with s2t2's I had this issue on the dyno. my tuner thought it could be caused by exhaust restriction caused by the fat dent in one of the runners in my header. He just about almost tuned the glitch out. I had no issues until one day I had my muffler replaced. The moron exhasut guy replaced my 2.5" muffler with a 2.25" (The whole exhaust, cat, resonator, collector was 2.5"). the first time it crosse dinto vtec after that i had that issue.
I tracked the car not long after that and all day dealt with the annoying poppoppopop at vtec cross over... it sounds painful especially when feathering to full throttle around turns between 5500-6000rpms. it definately held some of my straitline speed back.
So i recently had the 2.25" muffler replaced with a 3" magnaflo and the rough crossover is almost gone. I've gotten on it several times and only had that issue once and it was not nearly as bad as it was before. I will be back to the tuner soon to see if he can tune it out.
Of all the research ive done, i havent found a single definitive answer but i have read several times about folks who reverted to stock cams. that wasn's a solution i wanted to consider. I know it seems unlikley that exhaust restriction would cause this but i have a hunch that it is related, especially since my issues are almost clear.
Old Mar 8, 2012 | 05:20 PM
Faassstttt's Avatar
Check the valve lash for the vtec lobes. Sounds like you may be shifting to improperly lashed valves when VTEC cuts in.... Could also be improperly gapped plugs... Please let me know what the solution is.
Old Mar 8, 2012 | 05:56 PM
c5stunna's Avatar
Thanks that sounds like something it could be. It doesn't start up like it should either so ill adjust them an let u guys know thanks for the input
Old Mar 8, 2012 | 07:12 PM
allums34's Avatar
i had that problem it was my vtec solenoid ichange the whole unit not just the top part
Old Mar 8, 2012 | 08:22 PM
iwannarace's Avatar
you can't set the valvelash between the vtec lobes and the regular lobes independently. you set the valvelash period. let us know if the valve adjustment does it.
Old Mar 8, 2012 | 09:04 PM
Shaunathan's Avatar
there is no way people are this dumb
Old Mar 9, 2012 | 12:40 AM
ibiris's Avatar
Defo check the valve lash clearances. I'm assuming you have the clearance specifications for the new cams?
Old Mar 9, 2012 | 05:11 AM
purgat0ry's Avatar
Have EITHER of you had the seemingly doomed engines tuned by a professional?
Or are you just swapping cams n **** cause its hella cool y0?
Old Mar 9, 2012 | 10:15 AM
ktsciv93's Avatar
get adjustable cam gears, degree your cams, get it tuned.
Old Mar 11, 2012 | 11:04 PM
eg6 type-R's Avatar
come on people..
he needs to get it tuned if he is using rougher camshafts..
u just cant slap on stage 2's or 3's and expect it to run without problems..
Old Mar 11, 2012 | 11:11 PM
lome1232's Avatar
^^tune
Old Mar 12, 2012 | 12:19 AM
doood's Avatar
been there done that
i was gonna say get a tune, but that horse has been beaten.
Old Mar 16, 2012 | 08:45 AM
iwannarace's Avatar
http://hondaswap.com/general-tech-ma...ssover-335956/
https://honda-tech.com/forums/honda-prelude-4/official-%22why-vtec-doesnt-engage%22-thread-830163/
https://honda-tech.com/forums/acura-integra-6/sputtering-vtec-after-cam-install-1706719/
https://honda-tech.com/forums/all-motor-naturally-aspirated-44/installed-cams-eh-1296978/
Some other threads with useful info...
racinhatch
Apr 26, 2008 10:27 AM
RiSiNgDc2
Mar 11, 2006 09:08 PM
delsol31603
Jan 24, 2005 08:52 PM
bpowa
35
Oct 18, 2004 09:43 PM
dpine
11
Nov 3, 2003 10:20 AM
