clutch will slip on some passes but not always
Old Mar 8, 2012 | 02:34 PM
ashb82's Avatar
Default clutch will slip on some passes but not always
i got a clutch master fx500 4 puck unsprung clutch. on the street it never slips, but at the track with slicks it will slip some passes and not on other passes. is this normal for a 400hp car. i took the clutch off and it looked good. i did not see any bad heat spots or warpage.
could it be the pressure plate.
Old Mar 8, 2012 | 03:31 PM
90blackcrx's Avatar
Default Re: clutch will slip on some passes but not always
Does it slip more when heated up ? Clutch master adjusted correctly ?
Old Mar 9, 2012 | 12:59 PM
95dxsir2's Avatar
what flywheel?
Old Mar 9, 2012 | 02:00 PM
ashb82's Avatar
h2b evo kit
Old Mar 9, 2012 | 02:58 PM
slowboy90's Avatar
ash this is stanley hit me up if you need a clutch bud
Old Mar 9, 2012 | 03:12 PM
95dxsir2's Avatar
i had my CC stage 4 clutch adjustment set too low. once i adjusted it up, problem solved. first time out, i tried pre loading, and the clutch started slipping...slipped the whole way down the track cause i got it too hot. next run i said f it, and dumped the clutch...grabbed hard, but started to slip at the top end. hope this helps...
Old Mar 9, 2012 | 04:44 PM
ashb82's Avatar
did it stop.
because my clutch slips up top but looks like new when removed it. i dont want to buy a new clutch if its not the problem
btw stanley my car ran 7.5 1/8th with the clutch slipping
Eg_Hatch92
Transmission & Drivetrain
Dec 11, 2014 09:43 PM
TOP END MS
Dec 15, 2006 07:06 PM
ELSpool
Sep 13, 2004 06:33 AM
dohcdelsol
14
Aug 16, 2004 10:42 AM
Drag3GSR
Jun 15, 2001 06:01 AM
