Can't get starter back together!!!
Old Mar 8, 2012 | 01:46 PM
77chev7777's Avatar
Default Can't get starter back together!!!
Look at the diagram. Part number 11 has slid out of the starter body and I cant get it back together. The side with the short shaft has 2 washers on it, and sits between 4 small spring loaded magnets inside the body. Two of the magnets are sprung out, prohibiting the shaft from sliding into place. They move freely when I push on them but because of their spring-loaded action the shaft will not slide into its place. Any way to fix this or can I take it to a garage or something???
Old Mar 8, 2012 | 01:48 PM
77chev7777's Avatar
Default Re: Can't get starter back together!!!
Also just for the record Its a 94 del Sol 1.5 manual, nps
and the schematic is just for reference Idk if it is the actual starter or not....
Old Mar 8, 2012 | 01:54 PM
Lil Gnome's Avatar
Why did you take your starter apart?
Old Mar 8, 2012 | 02:26 PM
77chev7777's Avatar
Its a long story....lets just say it was an accident.
Happened when I was trying to split the starter from the motor It was in real tight so I thought I was missing a bolt or something...Ended up with this mess. Is my (was) perfectly good starter salvageable or do I need a replacement?
Old Mar 8, 2012 | 02:54 PM
Tony S.'s Avatar
Check and see if there is a small hole near where the magnets stick out. If so that hole is there so you can stick a paperclip or something in there to hold the magnet back while you put the other part in.
Old Mar 8, 2012 | 03:55 PM
77chev7777's Avatar
No dice. Any other options??
Old Mar 9, 2012 | 03:29 AM
77chev7777's Avatar
Is there supposed to be some type of hole Im missing or was that just a wild guess?
Old Mar 9, 2012 | 06:46 AM
77chev7777's Avatar
Where's all the know-it-alls when you actually need one......
Old Mar 9, 2012 | 10:30 AM
Stoodybayker's Avatar
Put the part with the magnets on it in the armature BEFORE you put the whole assembly back in.
Old Mar 9, 2012 | 10:54 PM
Lil Gnome's Avatar
Could you go to a junkyard(take one apart there, maybe even grab parts you're missing) or borrow someone's to see how it all would go back together? Or would you rather just try to get it together without that hassle?
Old Dec 15, 2013 | 04:04 PM
Dc2_ShowStopper's Avatar
Did you ever figure out how to put it back ? I have the same problem . Sorry for bumpin an old thread
Old Dec 15, 2013 | 04:30 PM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
When my brother too my starter apart by mistake. I used a small scribe to hold th magnets back to get the shaft in place. It took about an hour of messing with but still works to this day.
Old Dec 17, 2013 | 07:33 AM
77chev7777's Avatar
No, its been sitting on blocks ever since out in the back 40.
Just messin, I had to buy a new one.
Old Dec 17, 2013 | 07:44 AM
purgat0ry's Avatar
OP Delivers, wow.
Starters are pretty cheap.
I do have a D15b7 starter I'd be willing to part with if you're looking for a known good
Myb20integra
Sep 15, 2014 02:14 PM
Tim 59
Honda Civic (2006 - 2015)
Sep 1, 2010 10:30 AM
blaster834
Oct 22, 2004 11:09 PM
