95 b18b ls into 89 crx hf
Old Mar 8, 2012 | 11:56 AM
Adam Silkwood's Avatar
Default 95 b18b ls into 89 crx hf
So i have obd1 ecu dizzy. Doimg my hf injectors on the ls i have the motor transmission, axles, intermidiate shaft dx knuckles, ls alternator hf and ls harness i have the mounts and shift linkage from hasport. So from the research i have done i will need the obd0 to obd1 jumper to ecu and dizzy and i have to wire in a 4 wire o2 sensor and use the hf harness is there any other wiring tips or advice anyone has for me becuase its the only car i have and i have a week to do the swap do to work and school so anything else i should be aware of. Advice would be much appreciated. This is my first swap
Old Jan 21, 2013 | 01:14 PM
byebyesubbie's Avatar
Default Re: 95 b18b ls into 89 crx hf
What ecu are you using?
Adam Silkwood
25
Mar 18, 2012 12:00 PM
xXhellxraiserXx
Jan 15, 2012 10:23 AM
Jackson_Si
11
Jun 19, 2008 08:29 AM
AJxr
Jan 15, 2007 07:18 PM
Jules Winnfield
Apr 6, 2004 08:42 PM
