trunk spring
Hey folks, I have a 03 accord sedan and want to remove the back speaker panel for woofers, does any one know any aftermarket kit for a trunk shock as I will need to remove and cut a hole in the panel to fit the 10 inch wooofers I plan to put in place.
OP that may require a lot of work. I don't think there is room for a shock body, like other OEM trunk system that uses it (thinking about a Chevy Colbalt as reference). Not to mention some drilling and metal fabrication.
Just to throw out ideas, the trunk does have counter balance weights. Not sure exactly where it is on a Gen 7. You may want to play with that, if you are going to remove the springs.
tvomalley
Oct 26, 2008 07:58 PM
Bruce Banner
Jun 29, 2007 08:19 AM
SpoonREVS
22
Sep 9, 2004 09:21 PM
funkylemons
May 16, 2002 03:44 PM
