n Popping noise???
Old Oct 10, 2002 | 12:12 PM
PearlWhiteAccord's Avatar
Default n Popping noise???
anyone know why there is a popping noise when i step on gas from a stop and when i brake slightly...this sound comes out occasionally...dont know what it is..
Old Oct 10, 2002 | 12:24 PM
RotaryBzzz's Avatar
Default Re: n Popping noise??? (PearlWhiteAccord)
i'm giving you an award for the vaguest description of the day! congrats!!
no seriosly, why don't you mention where it seems to be coming from?
Old Oct 11, 2002 | 06:42 AM
Default Re: n Popping noise??? (RotaryBzzz)
sorry about that...
sound is coming from the right front....i have been hearing this sound for a while...near the tire
Old Oct 11, 2002 | 01:22 PM
GimpyAccord's Avatar
could be a lot of things... maybe endlinks on sway bar worn out??? balljoint(s) hosed??? spring moving around...
describe your suspension setup to us.
what year/milage car do you have?
[Modified by GimpyAccord, 2:23 PM 10/11/2002]
Old Oct 11, 2002 | 01:47 PM
YodiBrodi's Avatar
Default Re: n Popping noise??? (GimpyAccord)
does it do it when you turn also? does it pop it rapid succession or just occasionally? if it pops quickly and somewhat quietly sounds more like your cv boot is torn more than anything else to me. if it sounds more like a clunk then it would be bad suspension bushings somewhere. i had a missing sway bar bushing and never heard anyhting to suggest it was gone. i saw it was gone while replacing the struts. remove the wheel and look behind the knuckle where the half shaft runs through it. if there are any tears anywhere on that rubber boot its time for new halfshafts. better to get them both replaced at the same time. i think you can take your old ones to honda and trade them for rebuilts for about $100 a shaft. never done it so i don't know for sure, just heard you can but you know how that can be sometimes.
[Modified by YodiBrodi, 10:54 PM 10/11/2002]
Old Oct 11, 2002 | 11:24 PM
ratherbewalking's Avatar
i think i may know the problem this person is talking about. ive heard the phantom pop. it sounds as thou it comes from the catalitic converter or something. it actually happened tonight. im in first gear and i give it full throttel and the car goes pop. anyone else have this?
Old Oct 11, 2002 | 11:27 PM
Accord94DX's Avatar
Default Re: n Popping noise??? (ratherbewalking)
replace the #3 piston, left rear shock, and right turn signal bulb.
Old Oct 12, 2002 | 01:09 AM
Default Re: n Popping noise??? (Accord94DX)
front or rear turn signal bulb?
Old Oct 12, 2002 | 09:26 AM
Accord94DX's Avatar
hm....better do both just to be safe.
Old Oct 13, 2002 | 07:18 PM
Accord94DX's Avatar
Default Re: n Popping noise??? (sk8ordie)
I agree, that would fix the problem. I've heard people having problems with the back up light bulbs too... ya know popping and stuff... umm is that your car drifting on the ice rink behind our work??
not quite maing
Old Oct 15, 2002 | 05:27 AM
its a 94 lx, stock springs with tokico blues..just got them a month ago...the popping noise was there be4 this setup..and still contiunes...it sounds like a clunk too and the noise disappears until i slow down.. and it clunks again...
one clunk per slowing down and one per accelerating...
the sound doesnt come when turning...
IvebeenHatched
Honda CR-V & Element
Oct 8, 2015 09:01 AM
mr_munro
Suspension & Brakes
31
Feb 25, 2012 10:52 PM
bbbsti
10
Nov 26, 2010 02:54 PM
Championship
Jun 19, 2007 04:37 PM
