Need tips on doing a compression test
Old Mar 7, 2012 | 04:15 PM
motegicivic's Avatar
Default Need tips on doing a compression test
96 Civic EX
I had a few questions about doing a compression test.
I guess you can screw it in the spark plug hole and then go crank the car, one person can do it right?
You unplug the coil wire right, I read somewhere you pull the ecu fuse, I guess pulling the coil wire is fine by itself?
When you hold the gas to the floor and crank it, how long? Esp if you are doing it by yourself and can't see the gauge.
Old Mar 7, 2012 | 04:31 PM
vitamin_c95's Avatar
Default Re: Need tips on doing a compression test
Originally Posted by motegicivic
96 Civic EX
Umm...mostly correct. You have a coil on your 96? Pulling the ECU fuse should be sufficient. One peson can do it. The hose should be long enough for you to place it on the intake or something and view from your seat as you crank. Remove all plugs so the engine will "bump" as the cylinder you are testing will be evident. You want to hear the engine turn over about 6 times.
Old Mar 7, 2012 | 06:50 PM
Dc4LsTeG's Avatar
EK9
This. If not I just had someone crank my car while I watched it. And make sure you hold the throttle down the whole time.
Old Mar 8, 2012 | 05:13 AM
kyden's Avatar
i would just unplug the distributor. easy enough without having to find a fuse.
miguey310
Jul 26, 2009 09:03 PM
xJDMCx
May 29, 2009 06:10 PM
the.hamburglar
14
Jul 29, 2004 10:45 PM
Toda Built
May 13, 2003 04:42 PM
