I have ecu ?s
Will it work, sure. Will it be throwing A/T codes Yes. Your best bet would be to find a 5spd P12 ECU. Or if you know anything about soldering. You could try the A/T to Manual mod. OPen up the ECU and remove resistors rp17 and rp18, then replace rp18 with a jumper wire.This will convert the ecu to 5spd.
arsalanshj
Jun 4, 2016 09:38 PM
