EG b18b1 swap wiring problems
Old Mar 7, 2012 | 12:22 PM
ehrkeith's Avatar
Default EG b18b1 swap wiring problems
Ive searched around and I cant really find the answer for this, i got an obd1 b18b1 im putting into a 94 civic coupe, it had a d16y8 swap when I got it, but I dropped that out and sold it in favor of this DOHC, but anyways I can't figure out the wiring. I have harness I bought but it doesnt really match up at all on the wires.
I have 3 plugs on the drivers side, one of those has 4 wires just for the injectors, and the integra harness won't plug into this. I can post pictures if necessary but maybe I'm just missing something really easy.
Thanks
Old Mar 7, 2012 | 01:18 PM
DelSol-B18's Avatar
Default Re: EG b18b1 swap wiring problems
D16y8 is obd2. So the chassis harness is prob obd2 now. Switch the chassis harness to the stock obd1 and it's plug and chug. Simple
Old Mar 7, 2012 | 01:29 PM
94EG8's Avatar
Seagull Management
Post pictures. Good ones, use the macro setting on the camera (the flower)
Old Mar 7, 2012 | 03:18 PM
dumafit's Avatar
if you're putting a b18b1 into a 92-95 civic, just use the b18b1 engine harness and plug it into your 92-95 civic chassis harness, and no wiring is required
Old Mar 7, 2012 | 03:24 PM
DelSol-B18's Avatar
He has a d16y8 so it's converted to obd2. He needs to change the chassis harness back over to obd1 then it's simple
Old Mar 7, 2012 | 03:28 PM
94EG8's Avatar
Seagull Management
Chassis harness would never have been swapped, I can almost guarantee you.
Old Mar 7, 2012 | 03:29 PM
HondaPartsHero's Avatar
Technical Hero
I doubt its converted to OBD2 that would require more than just the harness as the OBD2 Civic harness is one piece and the OBD1's are two piece.
Old Mar 7, 2012 | 03:42 PM
ehrkeith's Avatar
yeah im a dummy, the harness i bought is for a da
one look at my boys dc and i figured out what I did wrong
Old May 22, 2012 | 09:50 PM
hype_R's Avatar
if you still have this obd1 engine harness for the DA and its 5 spd I'll take it off your hands for the right price
Nate Boslet
Apr 17, 2017 05:16 AM
tharealjoedirt
Dec 27, 2009 07:40 AM
93JDMEGG
Nov 3, 2009 07:16 AM
length
Dec 2, 2003 08:21 AM
