is this a 92-93 or 94-00 a/c compressor??
stupid label wiped off when I pulled it out of storage so I have no clue which one this is...
anyone think they can ID it? ebay just has a bunch of generic pictures
That is one filthy ****. I see there are lines attached to it, that may be of some help. However, the only compressor that ends with -P06-A01 that I can find is for a '92 Civic.
lol, yeah, its dirty as hell. it still works but not very well.
I was converting the system over to the 94+ r134a compressor system as I had pulled a COLD blowing system off another car I parted. I just couldnt remember if I had gotten to the point of swapping the compressors or not and didnt want to have to pull the one installed if possible
anyway, thanks guys!
oh and yeah, you can put the newer stuff on the 92-93 cars. you just have to take it all from the compressor over to the hardlines that end on the passenger frame rail and leave the under dash stuff alone. thats where you can bolt the newer stuff correctly to the older stuff. instead of r134a oil, you use the r12/r134a dual purpose oil so the r12 expansion valve operates correctly. just fyi.
marqoid
10
Jun 28, 2013 04:41 PM
JohnnyEF
Jun 7, 2012 03:16 AM
