99/2000 Civic SI pushing water out of radiator at hight rpm?
Hi guys. I have a problem with my SI pushing water out of the radiator cap at hight rpm. Could it be a bad cap or cracked sleeve. We replaced the head gasket 2 times already. Everything torqued and installed properly. There was no visible cracks in the sleeves.
Thanks
Thanks
Got a new cap from Honda. Still blows water at high rpm. Head was checked for warping and it was good. Also pressure tested.
Option?
Option?
May be a bad water pump/pulley not circulating the coolant causing it to heat up. What's the mixture of coolant and water in it?
warlockip
Oct 6, 2008 09:02 AM
