AZ 1997 Eclipse GSX ^_^
Old Mar 6, 2012 | 07:39 PM
siperformance's Avatar
Default 1997 Eclipse GSX ^_^ E85_Fully_Built
Testing the water on to see what i can get for my GSX...first of the car has a clean az title! ICE COLD AC! no power steering as of now, but ill get that fixed just needs ps belt...now lets onto the good stuff...
2.4 block with 2nd Gen 4G63 Head
FIC BLUE MAX 1250 CC Injectors (Might swap them with the FIC 2150's when i get the fuel pump situation figured out)
Fully built head/block
BC 272 CAMS
BC Valves
BC Springs
BC Retainers
GSC Tick Lifters
MAP L19'S
Manley 8:5 pistons
Manley Rods
4 or 5" Thick FMIC
3 1/2 Straight Exhaust
FP3052 Turbo
TIAL 46MM WG
Stock mani ported
Stock intake mani ported as well
Stage 2 Shep Tranny
ACT 2600 Clutch
DSM Link V3 (DUAL MAPS E85&91)
Bunch of more stuff that I'm forgetting thats just on the top of my head...now ill be adding another fuel pump (3rd) or just doing a double pumper with the Walboro 400's...the car is street tuned on 30lbs on E85...ill be getting it retuned on both E85 and 91 once i get the 3rd fuel pump or the double 400 pumper,i just had the head gasket replaced not even 150 miles ago wasn't over heating just started to send the coolant to the over flow tank so i had the head gasket changed, and went with the MAP L19 head studs, did the front main seal, castle plug, pretty much everything that was needed to be replaced was replaced on the car no problems no oil leaks no over heating. Now as of the power #'s I'm not sure since i haven't dyno'd the car yet I'm pretty sure its 500+ easy since its a 2.4 and not 2.0...i did run the car once down the track on 91 and 27lbs and i did a 11.1@129MPH so I'm pretty sure i could crack the 10's easy now on 30lbs and e85...
TRADES:
350Z 6spd
G35 6spd
Supra MK4 (Manual Restored title is fine)
RX7 FD3S (Manual Restored title fine)
Evo 8 (Restored title is fine)
S2000
RSX Type-S
EG/EK/EM/DC Swapped (K Swap Preferred) if B series cash on top and at least $5 grand unless its super clean with clean title and AC!
Sti or WRX
Mazdaspeed 6
98-04 GS400/430
98-00 LS400
01-04 LS430
RHD Cars (Titled and Registered vehicles)
SALE PRICE $12,500...the longer i have i the car the money ill invest in it(i.e. EVO 8 Brembo brakes, EVO 8 seats,possibly going back to a gt40r) and i have no problem keeping the car its a perfect daily drive i get around 300 miles on a full tank and e85 only cost $3.19 here in AZ :D so for $40-45 full tank...
Old Mar 7, 2012 | 01:38 AM
brevlle's Avatar
Default Re: 1997 Eclipse GSX ^_^
damn it, I had just put on new pants before opening this post.
Old Mar 7, 2012 | 02:09 PM
^ LOL thats a good one!
BUMP
Old Mar 8, 2012 | 12:23 PM
bump...will also consider eg/ek/em or dc integras but you will have to add cash on top of course :-) and no junk please..clean swapped civic's or integra's
Old Mar 9, 2012 | 12:22 PM
Afternoon bump
Old Mar 9, 2012 | 12:35 PM
brevlle's Avatar
This always pops up when I am getting ready for work, damn you BUMP FOR THE SEXIEST 2G I HAVE EVER SEEN!
Old Mar 9, 2012 | 02:56 PM
Snowden's Avatar
Truly another example of my west coast envy.... ahhh illinois... facepalm*
Old Mar 9, 2012 | 09:28 PM
josB's Avatar
wow... Perfect DSM
Old Mar 10, 2012 | 10:27 AM
thanks guys...i tried to keep the car as stock(exterior) as possible and as much of a sleeper as i could :-)
Old Mar 10, 2012 | 09:38 PM
bump updated the trades and put up a price up since I've gotten a quite a few pm's on the the price...
Old Mar 12, 2012 | 12:07 PM
Bump
Old Mar 17, 2012 | 12:23 PM
Bump...
Old Mar 22, 2012 | 06:56 PM
bump...
Old Mar 23, 2012 | 08:10 AM
macspeed's Avatar
interested in a 99 slightly modded bmw m roadster...yes it has ac
Old Mar 23, 2012 | 04:59 PM
Pm'd
D-Rob
Jun 11, 2014 04:25 AM
.CUBISH.
Nov 19, 2012 04:18 AM
D-Rob
Jul 9, 2012 07:57 PM
christian7750
20
Mar 1, 2009 02:32 PM
