-------93 Del Sol Turbo Catch Can HELP!----
Old Mar 6, 2012 | 03:24 PM
Nate Case's Avatar
Default -------93 Del Sol Turbo Catch Can HELP!----
So heres whats all to my Del Sol
:D16Z6 Vtec
:Lsd 5speed Transmission
:Skunk2 Intake
:TD05 16G Turbo
:Intercooled
So heres my problem: Recently my catch can is smoking excessivley. When it was first setup it smoked a bit, more of a vapor smoke, but now its smoking way badd.
Heres a picture of what its doing.
Ive been told pcv- dont think its that
Ive been told to vent my crankcase- Hints Catch can setup
Ive been told Ringland- Hoping its not that
Any help would be greatful fellas.
Old Mar 6, 2012 | 03:28 PM
Nate Case's Avatar
Default Re: -------93 Del Sol Turbo Catch Can HELP!----
Old Mar 6, 2012 | 03:31 PM
Dc4LsTeG's Avatar
EK9
As I told you and everyone else did. Do a compression and leakdown test. I'm still gonna guess cracked ringland
Old Mar 6, 2012 | 03:39 PM
Nate Case's Avatar
Should i replace the pistons and all that or just go with bseries? seem like they can hold more abuse.
Old Mar 6, 2012 | 03:44 PM
Dc4LsTeG's Avatar
EK9
Do the compression test and come back and post the numbers here. Also if any of the numbers look low add oil to the cylinder and re test
Old Mar 7, 2012 | 06:10 PM
NonovUrbizniz's Avatar
Loved
1. Is it a drain back Catch can?
2. If so are you sure the drain isn't kinked?
3. If not have you drained the catch can?
4. Is this picture taken:
- At Idle
- At high RPM
- With the car cold
- With the car hot
5. Is it constantly/steadily smoking? Or does it get dramatically worse when driving the car? Worse in vacuum or boost?
Old Mar 8, 2012 | 06:54 AM
Nate Case's Avatar
Catch can drains into back of the block-
Im sure its not kinked, i took the can out drained it, cleaned it. put it back in.
I took the 2 hoses off the valve cover and started it up, and the smoke comes from the ports in the valve cover. its is definately internal problem.
Its smoking worse and worse, low oil pressure, boost takes along time to build up.
Old Mar 8, 2012 | 07:25 AM
kyden's Avatar
motor is toast. who tuned it?
Old Mar 8, 2012 | 09:19 AM
lsturbo33's Avatar
I bet you had a boost spike from that manifold and damaged a few pistons.
Old Apr 7, 2012 | 10:58 AM
Nate Case's Avatar
Finally got pistons pulled..
Im going to replace with all new pistons bearings gaskets.
Probably use stock rods and low compression pistons.
Im just going to run into a problem when it comes back to timing...
Anybody got a good run through of how to set the timing on this d16?
Old Apr 7, 2012 | 11:00 AM
Nate Case's Avatar
Old Apr 7, 2012 | 11:03 AM
Dc4LsTeG's Avatar
EK9
What did the pistons look like?cracked ringlands? And search there's plenty write ups on timing
Old Apr 7, 2012 | 11:07 AM
Nate Case's Avatar
ill take more pictures. they look burnt. one piston looks really clean, the other three are toasty. The rings looks good still though. i think the problem may be within the valves in the head. Taken it to get hot tanked and rebuilt.
Old Apr 7, 2012 | 11:09 AM
Dc4LsTeG's Avatar
EK9
So no cracked ringlands? The ringlands aren't the actual rings themselves its the part of the piston in between where the rings sit
Old Apr 7, 2012 | 11:17 AM
Nate Case's Avatar
i see no cracks in them. i have a rough spot within my 3rd cylinder though. kinda looks like a spider crack. idk if that may the problem or not. Honer may take it out..
have any opinions on these pistons?
http://www.ebay.com/itm/YCP-Vitara-P...sories&vxp=mtr
Old Apr 7, 2012 | 11:21 AM
Dc4LsTeG's Avatar
EK9
Those pistons are good. Pic of cylinder wall? Dont know how it could get a spider crack
Old Apr 7, 2012 | 11:23 AM
Nate Case's Avatar
it may not be a crack..but it you slide your finger nail around it my finger nail catches on it.. Ibet once its honed out itll be gone
Old Apr 7, 2012 | 11:43 AM
Nate Case's Avatar
Ok, after going back looking at the pistons...
Man you know your stuff...
Ringlands are cracked and just falling apart.....
Old Apr 7, 2012 | 11:44 AM
Nate Case's Avatar
Old Apr 7, 2012 | 12:59 PM
Dc4LsTeG's Avatar
EK9
Lol there it is! I figured that's what your problem was, same thing happend to me
Old Apr 7, 2012 | 08:42 PM
rclark's Avatar
Ouch, that's ugly.
Old Apr 8, 2012 | 01:00 PM
Nate Case's Avatar
welp, low compression pistons on the way and block honed. thing should run pretty decent once put back together: )
Old Apr 10, 2012 | 03:20 PM
Nate Case's Avatar
Old Apr 10, 2012 | 03:43 PM
Loved
Painting those AN fittings was not a good idea.
leillox88
16
Nov 7, 2014 11:22 AM
skillz72499
Northeast (Sales)
May 16, 2007 10:48 AM
93hondadelsol8psiturbo
Apr 30, 2005 04:56 PM
LLZuB
Mar 11, 2002 06:19 PM
