compression and leak down test
Old Mar 6, 2012 | 01:34 PM
allums34's Avatar
Default compression and leak down test
i have 93 civic with a b16 motor, my question is will a leak down test or compression test let me know what problem i am having. my engine smokes when i come to a stop, and on top end when vtec kicks in. i check the oil every day full i check the coolant every day full i have horrible gas milage so i know i am running rich but shouldnt it smoke all the time since i am running rich. by the way the smoke is black. engine light only comes on at top end for tps sensor. i just want to make sure i fix the right thing cause money is super tight
Old Mar 6, 2012 | 01:36 PM
grumblemarc's Avatar
The Grumpiest
Default Re: compression and leak down test
Sure.
Old Mar 6, 2012 | 01:44 PM
MySickSi's Avatar
Well in vtec your engines dumping in alot more fuel since mre air is going in so that might be reason why it smokes when in vyec, the stopping thigh im not sure, what ecu are you running
Old Mar 6, 2012 | 04:07 PM
allums34's Avatar
i am running p28 ecu
Old Mar 6, 2012 | 04:51 PM
MySickSi's Avatar
Any cel?
Old Mar 6, 2012 | 05:07 PM
allums34's Avatar
cel #7
jakop92
Oct 14, 2010 03:13 PM
lsvtecpwr
11
Jul 15, 2007 10:28 PM
sohc_coupe24
May 10, 2006 03:45 PM
andysila
Dec 22, 2005 05:26 PM
crashoveride
Oct 5, 2003 10:00 AM
