Suspension & Brakes Theory, alignment, spring rates....
loose steering wheel??
Old Mar 6, 2012 | 08:18 AM
jimmy051702's Avatar
Default loose steering wheel??
I have a 97 Teg just replaced my Axels tires and brakes....my steering weel is loose while driving and when I turn it tightens up. I did not do an alignment when I did this stuff but had it done before. My tie rods looked a little messed up when I changed the Axels. Any ideas? Tires were balanced when switched
Old Mar 6, 2012 | 08:24 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: loose steering wheel??
Originally Posted by jimmy051702
I have a 97 Teg just replaced my Axels tires and brakes....my steering weel is loose while driving and when I turn it tightens up. I did not do an alignment when I did this stuff but had it done before. My tie rods looked a little messed up when I changed the Axles. Any ideas? Tires were balanced when switched
I think you answered your own question.
Old Mar 6, 2012 | 08:28 AM
Would the tie rods cause that?
Old Mar 6, 2012 | 09:05 AM
grumblemarc's Avatar
The Grumpiest
So if we say no does that mean you won't change them?
Old Mar 6, 2012 | 09:10 AM
98civdx's Avatar
Master Detailer
Check the tie rods, lower and upper ball joints. Also, check for torn bushings.
Old Mar 6, 2012 | 12:28 PM
No I'd still change them just trying to pin point the issue.... 98civdx thanks will do that was going to be the next few things I.changed
Old Mar 6, 2012 | 01:02 PM
The Grumpiest
Then maybe you might want to fix ALL the deficiencies pertaining to the steering system then?
Old Mar 6, 2012 | 03:20 PM
seanbev24's Avatar
Do this. Replace anything that's loose. Get an alignment.
Da_1991
Jan 24, 2012 07:39 AM
lxdriver
Suspension & Brakes
Nov 30, 2011 06:57 PM
*ctrlaltdel
10
Sep 25, 2009 11:02 AM
vultron
Nov 11, 2004 07:05 AM
project_DC2
Jan 30, 2002 09:46 PM
