What motor/tranny do I have?
Old Mar 6, 2012 | 07:50 AM
H22_CB7_JAY's Avatar
Default What motor/tranny do I have?
Hello all,
I have a couple issues with my Jdm H22A idle. Before troubleshooting I am definately interested in what year prelude this motor came out of. I have no clue how to check. Also, once I determine the year, I would need to know what ECU would naturally come with the motor. I just got this car 2 weeks ago for 600, and the IACV/FITV were NOT hooked up, the car was running (awful) on the BASEmap ecu. I also have a P06 Teknotik (Chipped? Tuned?) ECU which makes the car agressive as f*k.
Any help would be greatly appreciated.
Old Mar 6, 2012 | 09:35 AM
Arthas's Avatar
Default Re: What motor/tranny do I have?
There is a VIN behind the block by the oil pan. As for the year check the head, there should be two numbers.
I would really recommend getting rid of that ECU. ECU's with base maps are nothing but problems.
Dont quote me but if its 96 99 H22A its P5P. If its 92 95 its P13.
Old Mar 6, 2012 | 10:09 AM
Thanks! But, honestly between the 2 ecu's the basemap runs the best! Besides my idle going up n down, and at operating temp. she drops to 0 almost killing the car, then shoots up to 1200 or 1,000.
To better explain, I made a video! Here it is guys (I had the car on so you can't see the idle going up n down to warm the car up, it stops doing that.. and this starts, once she is off cold:
http://www.youtube.com/watch?v=BuzqR...ature=youtu.be
Ne help would be sweet. Also, when I got the car the FITV and was NOT hooked up. I ran 2 coolant hoses to it, 1 from the IACV and I THINK?! I fixed it. I'm assuming the choked rev would have to do with a clogged fuel filter?
Old Mar 6, 2012 | 10:18 AM
In this picture beside these 3 circles it says P13. Is that what I should go by? Also, I can't really read the exact year, plus there is 2 circles with an arrow in each.. lol see pic:
Old Mar 6, 2012 | 10:26 AM
I've also noticed the P13 markings on my TB, I.M, And some other random places I beleive. I'm leaning towards the fact that it is definately 92 to 95
Old Mar 6, 2012 | 10:55 AM
Arthas's Avatar
Yup, P13 it is.
Old Mar 6, 2012 | 11:06 AM
GhostAccord's Avatar
That's kind of sounds like it's more in the tune. I would suggest that you get everything hooked up properly. The coolant hoses all hooked up to the FIT & IAC valves. Make sure there are no vacuum leaks. Then you should ether run a stock OBD1 P13 or get one of your chipped ECU's tuned.
Where you just bought someone's problems. It's kind of hard to tell what, if anything, has been done with the wiring as well. What year Accord is this in would be helpful as well?
Surging idle can be caused by;
Air pocket in coolant system or ECT sensor not working or not pugged in
Vacuum leak
Dirty or malfunctioning IAC valve
improperly adjusted FIT valve
Where your surging issue seems only to be until the engine warms up. I would point toward the FIT valve for that warm up surging issue. As for that low burp after it warms up, that seems like it might be a tuning/temp fuel correction thing. Check your ECT sensor.
Old Mar 6, 2012 | 01:09 PM
Vacuum leak
I respect and appreciate your time thank you. Its a 1991 Honda Accord EXR. JDM H22A Swap. Where would the ECT Sensor be? and what is it? Electronic control sensor? Also, Im cool with the fact I bought another person's problem, because I bought this car for 600 canadian dollars, and its absolutely mint inside and out. A little brain rattling won't hurt me at all either.
Old Mar 6, 2012 | 08:26 PM
Welcome to another fellow Canuck!
$600 is a pretty good price if she's clean and free from rust. I'm sure you can get it up and running properly if you take your time and troubleshoot.
The ECT is the engine coolant temperature sensor. It is the two wire sensor located in the head directly under the distributor.
919DumpedCD5
Dec 22, 2010 07:05 PM
h22a1_julien
Aug 12, 2007 05:32 PM
eg2_RE
Oct 26, 2004 10:43 PM
servion
Jun 18, 2002 08:33 AM
