temp gauge going up & down
Old Mar 5, 2012 | 08:04 PM
rudyndrew's Avatar
Default temp gauge going up & down
Its been acting crazy. When I drive for a while it goes up all the way like its over heating but its not. I checked all fuses n got a new mpfi harness done n a new temperature fan sensor. What else should I check? Its been doing for a yr but its getting worst making my fan go on the whole time plus I checked my hoses there routed correctly.
Old Mar 5, 2012 | 08:09 PM
KINGVEM^^ED6's Avatar
Default Re: temp gauge going up & down
Check your grounds ese
Old Mar 5, 2012 | 08:55 PM
rudyndrew's Avatar
Well the ecu n dizzy ones r new since its a new harness but the others seem fine to me. U know of a shop that can check it out for me locally? Even sometimes the gas one gets a lil fishy but rare.
Old Mar 5, 2012 | 09:02 PM
Take.off the.battery ground cable.and.clean up the contact.points
Also the.valve cover one
And thermostat housing.one
Abd naw brah don't know any
Old Mar 6, 2012 | 04:54 AM
Spug's Avatar
Also, double check to make sure you have no air in the coolant system.
Old Mar 6, 2012 | 06:59 AM
JDM__Surge's Avatar
I had that issue on my 91 sedan, I had a coolant leak on the collant resevoir, I fixed it and it kept on, I blow my waterpu.mp after a 90 minute straight, 70mph drive, I got it fixed, and it kept doing that to me, in my case it was my head gasket that had a small crack and it was leaking coolant into the engine. Check your compression to be safe, but then again my case was just a bad experience cuz then engine would get warmer than normal, in my case it was slightly overheating,
floatfisher
May 19, 2007 04:20 AM
GiceMob
Mar 26, 2007 09:06 PM
DOHCarp
Sep 19, 2003 09:35 AM
MeanGreenEG9
Jan 20, 2003 07:40 AM
