88 Hb Front end On a 91
Old Mar 5, 2012 | 02:31 PM
CYPR3SS's Avatar
Default 88 Hb Front end On a 91
Is should go on no problem right?
direct swap I mean.
& Also will the turn indicators be the same? on will i have to get new ones? any info please lemme know! thanks.
Old Mar 5, 2012 | 02:45 PM
Canadian_EF's Avatar
Default Re: 88 Hb Front end On a 91
is water a liquid?
Old Mar 5, 2012 | 02:46 PM
CYPR3SS's Avatar
thanks.
Old Mar 5, 2012 | 03:53 PM
24TEN's Avatar
PHANTOM MENACE
Bumper support is different and so are the bumper lenses. As long as you use the entire thing (bumper support with matching bumper and bumper lights, foam if it's still there) it'll go on without any trouble.
Old Mar 5, 2012 | 04:15 PM
90civic-ZC's Avatar
Originally Posted by Canadian_EF
is water a liquid?
Depends which state it's in.....
Old Mar 6, 2012 | 08:41 AM
Icon4 Re: 88 Hb Front end On a 91
ooooo Mr.Physicist. The Majority of substances are called different names depending upon the temperature and its effect on the shape or structure. changing the temperature can result in different outcomes. water is a liquid, ice is a solid, steam is a gas. so no, it doesn't depend on the "state" of the liquid. water is liquid, ice is solid, steam is gas. you don't see steam generators called "water generators" or ice-makers called "frozen water makers"
Old Mar 6, 2012 | 02:41 PM
csingham's Avatar
crazy mad murdock
So what your saying is that he is right and water is liquid
Old Mar 6, 2012 | 05:31 PM
floodx4's Avatar
Yet, we do have "Hot water heaters"....hot water should not need to be heated....we should have "Cold water heaters"....
Then again, we drive on a Parkway, and park in a Driveway?
4g4dcruisin
Sep 2, 2010 01:41 PM
patrickstar
Jan 18, 2009 07:21 AM
jpmlax88
Aug 3, 2003 06:56 PM
Milan
May 28, 2002 05:11 PM
