Where can i find a metal key for the D16Z6 cam pulley/gear?
So that little shim job that holds the timing gear to the cam. I have looked on majestic and when i go to auto zone or shmucks and ask them they look like there gunna start bleeding from the ears. So any one know where to pic something like that up at?
im pretty sure the "key" on the cam gear is ground out of it. ie: part of the cam gear. i had to replace my cam a few years back because i didnt put the washer onto the bolt holding the gear to the cam and it ground fu**ed it up. i actually lost the woodruff key to my crankshaft pulley and ground one out of a piece of metal stock. it worked fine for me.
Dont get so depressed bro, its literally like $3.28 at the dealership. Its not expensive at all. And even if you have to buy a new cam gear pulley to get it, its only $16.
Is this for an aftermarket cam gear? The factory keyway is built into the gear. The Honda part # for the key is 90741-657-000
Awesome guys i thanks for the info. Yeah my last one broke off so it jumped time. could not figure out what was going on for the longest time.
j0nptw
Aug 18, 2005 02:03 PM
