Need help, what is this called ? Where to buy it
Hello H-T I need help to find what this thing in red circle /red arrow pointing at, called and where to buy it. It on my dizzy plug on engine harness side, the cable so old, it broke there and it's too short for me to solder it. I try to de-pin but broke the rubber thingy, I'm hoping some one can tell me what it called and maybe where to buy it. It's hard to google it when I don't know what word to start. Plug rubber didn't make it in google
Thank you
Thank you
what your referring to is the weather pack boot. all of the terminals on the engine harness shock tower plugs use them. they are used to keep moister out.
Easiest way would be to find a new plug like DCRB suggested.
Then cut your existing wires and splice the new plug end in using solder and heat shrink tubing.
I use www.crimpsupply.com for weather pack. They ship same day and they have everything in stock.
It looks like you need a new seal. Here's a link: http://crimpsupply.com/packard-delphi/weather-pack
Thank you
Thank you
Your wires are forked so it's looking like you need the connector tips too.
How much does the crimp tool cost to properly put the connector ends on?
Still suggesting you replace the whole connector with a salvaged one.
TeggieeTuner
Jan 28, 2013 04:17 PM
cloviskilla
Jan 14, 2011 07:40 PM
RicedREX
Jul 18, 2004 02:49 PM
