Suspension & Brakes Theory, alignment, spring rates....
Drag suspension setup??
Old Mar 4, 2012 | 09:13 PM
EuroR808's Avatar
Default Drag suspension setup??
I needed some advice on a decent setup for my EG hatch.trying to stay within budget
I was thinking of going with blox drag coilovers
blox lca, camber kits, and toe kits
should i run rear spherical bearings as well??
I know a lot of ppl say that blox is crap but its also within my budget some insight would be appreciated
Old Mar 4, 2012 | 09:15 PM
EuroR808's Avatar
Default Re: Drag suspension setup??
I forgot to mention that I currently have a traction bar already and was thinking of going to go with an ASR subframe brace and sway bar kit
Old Mar 4, 2012 | 09:19 PM
98civdx's Avatar
Master Detailer
Is this a drag car?
if so, why in the world would you put a ASR/sway bar on it?
Blox is crap, period! You need to do some research.
Old Mar 6, 2012 | 06:48 AM
Libertariat's Avatar
Ek Forever y0!
Blox is junk.
I would get the Omni drag kit, or a Koni/GC combo with the rates you need.
Skunk2 camber kits are alright, I would be willing to try hardrace though.
What do you need LCAs for on a drag car? Much less a swaybar.
If you had proper drag rates, something like 400F 600R a typical sized rear swaybar won't do much, if anything.
And you don't need toe kits either, the factory toe arms are more reliable.
Old Mar 7, 2012 | 12:08 AM
EuroR808's Avatar
Originally Posted by 98civdx
Is this a drag car?
I've did some research but I was goin to throw the ASR kit on if I had the extra money left over, tell me were I can find a drag coilover that is better than the bloxs for under $800???
Old Mar 7, 2012 | 12:12 AM
EuroR808's Avatar
Originally Posted by Libertariat
Blox is junk.
You never heard of athletes say you look good you play good!!
I gotta have some style points while I go down the track thats why I wanted LCAs otherwise I would just leave it bone stock.
so all I need is just coilovers and camber kits and I should be good to go??
Old Mar 7, 2012 | 12:19 AM
Dc4LsTeG's Avatar
EK9
Then make sure you get some rear lcas, asr brace w/ huge sway bar, and a beaks tie bar. Those will all help a ton with those 60' times
Old Mar 7, 2012 | 01:53 AM
Ek Forever y0!
If you're going to get rear LCAs get PIC or F7.
Those are the only two I would buy.
Old Mar 7, 2012 | 08:39 AM
Hippslsvtec18's Avatar
go with progress csII's they have a drag setup with 350 front 500 rear, for right around $500-600. if you want something even harder for the track, progress will set you up with the CS1's with your choice of custom spring rates, at right around 8-900.. progress FTW
Old Mar 7, 2012 | 08:43 AM
98civdx's Avatar
Master Detailer
Do some research buddy.
Old Mar 8, 2012 | 07:41 PM
EuroR808's Avatar
Blox is junk.
Are those spring rates going to be enough for an h2b, the motor weighs more than your typical b series so I think there is going to be more weight up front, also I don't want the car to see-saw when I launch
were can I get the coilovers and LCAs from??
Old Mar 9, 2012 | 02:15 AM
Ek Forever y0!
An h22 weighs ~30lbs more than a b-series.
How much should you compensate?
Also, I I bet you gave up PS, or AC, or both, which probably saved you 30-45lbs over people who run b-series engine and have both.
What kind of LCAs do you want?
The only two I would even consider are Function7 and PIC.
PIC you can buy direct, and Function is sold by a lot of vendors. THMotorsports, king motorsports, weaksauce, JHPUSA, etc.
Muckman
Nov 29, 2012 08:42 AM
kielcivic
Suspension & Brakes
Jun 9, 2012 12:37 AM
BLK2DOOR
Jan 21, 2010 01:27 AM
BARTEG
Suspension & Brakes
Mar 23, 2006 05:22 PM
revtechsi
Jan 3, 2003 03:20 PM
