Would a dc2 steering column be a direct swap into my EM1?
Old Mar 4, 2012 | 12:58 PM
Miami Honda's Avatar
Default Would a dc2 steering column be a direct swap into my EM1?
I bought what I thought was a ek9 steering wheel but ended up with a dc2 steering wheel and full steering column. Could I swap the whole thing into my em1?
Old Mar 4, 2012 | 01:56 PM
Deetz's Avatar
Crazy Honda Guy
Default Re: Would a dc2 steering column be a direct swap into my EM1?
Dc wheels don't fit EK splines......
You can use other EK models, S2000, EP3 and and DC5 designs
Old Mar 4, 2012 | 02:17 PM
I know that. Thats why I stated that I have the entire steering column also from the dc2 steering wheel. My question was if the dc2 column would be a direct swap into my em1.
Old Mar 4, 2012 | 11:52 PM
bump
Old Mar 5, 2012 | 05:32 PM
anyone pleaaaaase
Old Mar 5, 2012 | 05:37 PM
talonboy1991's Avatar
Theres a write up on swapping a s2k wheel into an eg they took the ek column and cut the mounting bracket off and welded the eg one on in its place. Im sure you could do the opposite the write up was on teamsolcal i think though im sure if you google search youll find what your looking for
http://teamsolcal.com/forum/thread-1489.html
heres the link youll need to do the opposite of what they did
Old Mar 5, 2012 | 10:53 PM
gsr_b20b's Avatar
this is so confusing, i have a ek4 steering wheel in my dc2.
Old Mar 10, 2012 | 09:15 PM
Well just in case anyone wanted to know a dc2 column swaps in perfectly into a em1. It was very simple too
Old Mar 11, 2012 | 06:29 AM
Deetz's Avatar
Crazy Honda Guy
Good to know, this is some great tech!!
Old Mar 11, 2012 | 09:19 AM
NotAJDMFanBoy's Avatar
For the splines, I know to swap an Integra column into a 5th gen Civic you need the Integra universal joint for between the column and rack.
6th gen integras are easy enough to find at the junkyard, just get one of them.
Old Mar 13, 2012 | 06:39 PM
I actually didn't need anything to swap it into my em1. Everything bolted the same exact way it did with the original column.
phaze
Sep 19, 2011 06:59 AM
ty521825
Jun 25, 2009 05:47 AM
EddieLe76
Apr 27, 2007 01:58 AM
mug3n1nteg
May 27, 2006 10:59 AM
