Ignition system
Old Mar 4, 2012 | 10:56 AM
shiroun's Avatar
Default Ignition system
(On a sidenote, making a new thread in the hatchback section is probably the smartest option).
I can't find a mate for this wire, it's the BATTERY wire on the ignition system. Last wire I need to connect to start my car. Can anyone help me out?
Old Mar 4, 2012 | 11:43 AM
91STDFLOW's Avatar
Default Re: Ignition system
The little letters that run along the lines are the wire color, abbreviated, figure out the color for the wire, find it and see wherr its at, or look for a unplugged plug that reaches and matches plug on ignition.
Yours truely,
Flow
Old Mar 4, 2012 | 11:50 AM
shiroun's Avatar
Yours truely,
Flow
I understand that,
However no wire seems to match up to the wire marked BATT, that flows into 45A.
That is my question, where should i find the mate for it?
Sincerely,
Shiroun
Old Mar 4, 2012 | 11:57 AM
91STDFLOW's Avatar
That 45a is a fuse, trace from there I guess
Maybe
http://www.hondahookup.com/manuals/
Has a better manual, or wait for someone else to chime in.
Best of luck,
Flow
Old Mar 4, 2012 | 12:24 PM
shiroun's Avatar
Maybe
Best of luck,
Flow
My problem, Flow, is that I can't find the fuse. I have absolutely NO idea where it's located since neither fuseboxes has a slot for it.
Sincerely,
Shiroun
Old Mar 4, 2012 | 01:03 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
You are saying the fuse box under the hood doesn't have a slot for it?
Old Mar 4, 2012 | 01:22 PM
shiroun's Avatar
Yes, and the plug won't even reach the hood. It's extremely short, it could maybe stretch to the passenger side ECU, for reference
EDIT:
55A is on the fusebox. 45A isn't. So that leaves the -*- to be figured out.
Old Mar 4, 2012 | 02:21 PM
DO IT ON ALL FOURS
Haha, the picture of your floorboard didn't load. You are trying to plug in the ignition switch wiring? The small plug goes into the left side of the under dash fuse box. The bigger plug goes into the dash harness.
Unless I am just not understanding what you are asking. Are you talking about the randomly placed ignition coil. I guess be more clear about that of which you are referring to.
Old Mar 4, 2012 | 03:22 PM
shiroun's Avatar
No, you're understanding it correctly. I'll check tommorow afternoon, but I was looking at the dash fuse box insessantly, and i couldn't find a spot for it anywhere.
Worst comes to worst, I'll just get a 12V fuse and run it directly to the battery.
Old Mar 4, 2012 | 03:33 PM
Spug's Avatar
I'm lost without a picture.
So.............................one end is connected to nothing, and you need to figure out where to connect it.
and,
the other end is connected to what exactly?
Old Mar 4, 2012 | 06:02 PM
shiroun's Avatar
and,
One photo back up. lost the other i'll fix it tommorow
Old Mar 4, 2012 | 07:26 PM
Spug's Avatar
I hate that picture. The coil pack should be in the engine bay, not in the cabin.
Old Mar 4, 2012 | 07:30 PM
shiroun's Avatar
Where does the ignition coil go in the engine bay? o_O
Old Mar 4, 2012 | 08:13 PM
Spug's Avatar
It's not a stock part, so I'm not really sure why you're even using it.
The stock coil is inside the distributor.
I'll pull my dash back out tomorrow and get some pics of the connections around the key cylinder and under dash fuse box.
Old Mar 5, 2012 | 01:18 PM
shiroun's Avatar
Hey spug, I ended up doing this to the ignition. Now it beeps when I ground it (atleast temporarily, then it shuts off pretty quick). Beep is all I get.
Edit.
I'm thinking of splicing the wires, getting 2 more 10g wires and 2 more of the splice things, and just using switches to start/cut power to whatever I want. Hoping that works.
Now, this eliminates the key-turn system, so I'm going to haveto come up with a way to have my own personal security on it. Not sure what I'll do.
Old Mar 5, 2012 | 03:25 PM
Spug's Avatar
Also keep in mind that if you plan on leaving the battery back there you're going to either have to vent the battery box to the outside of the car, or get a sealed battery that doesn't vent harmful vapors.
You're also going to need fatter wire to the battery, since the longer the run, the fatter it should be. You can shorten that ground up as well.
Old Mar 5, 2012 | 05:17 PM
shiroun's Avatar
Already increased the battery wire to 6 gauge I believe.
The box I have is sealed to avoid harmful vapors, i just took off the top for now.
I got power going, however this is all I can get (Rear lights, not sure if break lights work, head lights, and regular front lights. No turning signals (although plugged in), or windshield wipers.)
Edit: The lights in the above photo are my break lights. They're on when I ground the negative.
Gonna put some switches in tommorow. That might help.
Old Mar 6, 2012 | 01:16 PM
shiroun's Avatar
Didnt help. Disconnected all power to the ignition and the car magically turns on the breaks and headlights like this when grounded. I'm wtfing like crazy.
Edit:
Grabbed a multimeter, wires get power. I just need to feed them to where they're supposed to go and it should work.
Going to try that tommorow, if I can read this crap.
Yellow is BATT right?
Old Mar 6, 2012 | 05:49 PM
Spug's Avatar
Yellow what? There's alot of yellow wires.
Old Mar 7, 2012 | 12:33 PM
shiroun's Avatar
I'll take a photo of it tommorow first thing.
Old Mar 8, 2012 | 10:16 AM
shiroun's Avatar
Update: THink i figured it out. Will update in two hours.
Old Mar 8, 2012 | 11:05 AM
91 EF DX's Avatar
awesome
Old Mar 9, 2012 | 01:33 AM
Fatsmcgee808's Avatar
Its right here. It was a b*tch to find.
Old Mar 9, 2012 | 06:46 AM
DO IT ON ALL FOURS
I told you before where it went....
Old Mar 9, 2012 | 10:59 AM
shiroun's Avatar
You were right.
Turns out the sunroof and the ignition were wired together (WTF?).
Fixed the problem, put the stock ignition back.
Not all my grounds are set-up, so I don't have anything besides the BREAK light come on, and a smoking wire (lol 23g wire used in the ignition. ****ing idjit botched the wiring. Fixing it to 16/12g tommorow). Head my starter move a bit, but again, not all my grounds are set-up.
Thank you guys! I appreciate it!
williamcollins
Jul 8, 2017 01:24 PM
saikou
May 27, 2007 05:30 PM
noss88
Apr 19, 2007 09:28 PM
MidoriEK4
May 18, 2003 09:08 AM
