Rough warm Idle
Old Mar 3, 2012 | 08:56 PM
GGMK's Avatar
Default Rough warm Idle
My car's idle is acting all wonky when warm. After getting off the freeway, and stopping at a red light, stop sign, or whatever, the car's RPMs drop for a split second, it sputters a bit, and sometimes it dies. What causes this? Fuel injector cleaner doesn't solve the problem, and it doesn't happen when cold. Suggestions?
Old Mar 3, 2012 | 09:20 PM
90civic-ZC's Avatar
Default Re: Rough warm Idle
Any codes? CEL?
Old Mar 3, 2012 | 09:23 PM
Ej1God's Avatar
does your car have the original motor? if so, what model is it?
Old Mar 3, 2012 | 09:37 PM
Ej1God's Avatar
just saw answer to my questions, but id definitely check the CEL if your car threw one. if there's no CEL i would start with the spark plugs and plug wires cause when they bad or worn u can only tell when car is warm and not cold.
Old Mar 4, 2012 | 03:55 AM
m.e.s.a's Avatar
maybe a vacuum leak
Old Mar 4, 2012 | 04:25 AM
meadowvalien's Avatar
i was suffering from the same problem, i am a mechanic at honda, i had tested everything and i mean everything, finally i put some gas line anti-freeze in, problem solved! gas or fuel line antifreeze will absorb water and moisture in the tank which can cause idle sputtering, hesitation, low power at low rpm but not much differnce at high rpm. I used Iso-heet, $1.50 at partsource, give it a shot our older cars are more prone to getting water and moisture in there. Goodluck hope this helps!
GunSamir
Honda Civic (2001 - 2005)
27
May 31, 2014 09:06 PM
JDMFreakz
12
Jul 11, 2012 10:54 AM
2000turbosi
Mar 23, 2009 01:32 PM
Mik3
Feb 5, 2006 06:55 PM
quick gixxer
Jan 11, 2004 09:41 PM
