What should I do with my bumpers?
Old Mar 3, 2012 | 12:13 PM
gunsnbam's Avatar
Default What should I do with my bumpers?
Hey everybody I'm in the middle of my first paint job and after not knowing how to set up my gun I did a bad job at priming my bumpers. The primer is all uneven. Do I have to resand the bumpers or can I just spray more primer on top and just make sure to cover the spots that didnt get sprayed good last time? Can I also just spray over some of the previously primed spots on the rest of the car, where my dents where?
Also, I had scuffed them up pretty bad when I was sanding them. Is priming and block sanding going to fix these scuffs or should I just stop messing with the bumpers I got and just get new ones?
And my driver side side molding had a dent in it so where should I get a new one? Honda charges like $80 bucks and thats kinda high for me right now.
Here is a before pic
And how it sits atm
Old Mar 4, 2012 | 08:39 AM
prelude1897's Avatar
Default Re: What should I do with my bumpers?
It's okay to spray primer over spots that have been primed before, but what grit paper are you using? Before actually painting, I normally wet sand the areas so you don't see sand scratchs in the pain.t itself
Old Mar 6, 2012 | 07:57 AM
gunsnbam's Avatar
Can I prime my already primed bumpers while the current primer is still rough or should I sand it down a bit with 350 first?
I have been sanding most of the car with 80 grit because the car had a good 3-4 complete paint jobs on it but I plan to block sand the whole car with 350 before I spray it. Is that a good idea?
Is something around this quality possible for me?
Old Mar 6, 2012 | 08:10 AM
Builda'Teg_92's Avatar
That quality will take ALOT of prep, and a pretty good comfort level with a gun. 320 MIGHT leave sand scratches....i would sand with what your tech data sheet says to sand with.
Old Mar 6, 2012 | 02:45 PM
.hawaii's Avatar
just paint over them, or you can buy black trim paint. use primer filler to fill in those spots that are scuffed up, give em a good sand and shoot em with the black trim
Old Mar 7, 2012 | 05:44 AM
gunsnbam's Avatar
What do you mean by ALOT of prep? I'm new to car painting and I dont understand what people mean when they say this. If I block sand it good and have everything clean when I spray it what more can I do?
Old Mar 7, 2012 | 09:08 AM
its mostly said cause paint only takes a few hours, prepping the car for paint can take weeks. with my paint project (link in my sig) its comming out good but can see where i could have took more time. sure blocking a car dosent sound difficult but it kinda is, prime/block/prime/block/prime/block....plus sanding filler..ughhhh
thats only the first step
i would also practice with the gun your going to be using...making sure you paint with the gun flat on the panel, fan spray,psi, ect ect.
Old Mar 12, 2012 | 02:55 PM
EJ2GOON's Avatar
any one know how to paint polyurethane Bumpers and the side moldings?
Old Mar 18, 2012 | 07:28 PM
EFnCRX's Avatar
i would pratice alot before spraying your car. also youll need more then just 350grit for prep i thought it only came in 340g then 400.. leave car painting to the pros man
Old Mar 21, 2012 | 05:44 PM
rajuncajun's Avatar
everything MUST be sanded with 320 before repriming...and u can finish the car in 320 grit but the car will have to be sealed before base coat or just finish everything in 400. BASF makes a flat black called uno u can spray on your moulding tht looks OEM.
Old Mar 23, 2012 | 06:04 PM
(. )( .)'s Avatar
Block sand all the uneven spots and feather it out, than respray with one even coat. You can even do a guide coat and block sand after you re primer. Just to find the low-high spots.
Old Mar 25, 2012 | 05:50 PM
EFnCRX's Avatar
guide coats are a must for the amateur painter.
Jordan.F
Paint and Body
15
Apr 20, 2013 07:58 AM
Empyre JDM
Nov 27, 2010 08:52 PM
FhCRubarb
May 3, 2008 10:23 AM
SPORT INJECTION
Oct 16, 2004 12:46 AM
Nick H
Mar 31, 2002 04:44 PM
