Burned paint
Old Apr 18, 2013 | 08:41 AM
Jordan.F's Avatar
Default Burned paint
Any tips to remove that ? . I sanded already but its still like rought
Old Apr 18, 2013 | 08:51 AM
lostforawhile's Avatar
longest project ever
From: on the south side of dixie, 1986 Accord Hatch
Default Re: Burned paint
we need more information
Presidential_Detail's Avatar
Detailing Mastermind
Doesnt look burned, looks like your clearcoat is failing. Pretty common on factory Honda paint. You said you sanded it?
Old Apr 18, 2013 | 09:40 AM
Jordan.F's Avatar
I sanded but on this pic its not
Old Apr 18, 2013 | 09:41 AM
speedjunkie_g35's Avatar
From: Pensacola, FL and every Court House in Louisiana
Keep sanding!!!
Old Apr 18, 2013 | 10:13 AM
Jordan.F's Avatar
Ill get more pic this evening
Old Apr 18, 2013 | 03:29 PM
Jordan.F's Avatar
More and more sanding?
Old Apr 18, 2013 | 03:38 PM
Jordan.F's Avatar
Old Apr 18, 2013 | 03:43 PM
Jordan.F's Avatar
PanchoEK's Avatar
looks like the clear coat is faded... if it is, you're going to have clearcoat it again. there's no way you can sand and buff that
Old Apr 18, 2013 | 03:56 PM
Jordan.F's Avatar
So you think I can continue sanding with diff grift then ready to prime ?
Old Apr 18, 2013 | 03:58 PM
Jordan.F's Avatar
Seems removable with harder grain
Old Apr 18, 2013 | 08:02 PM
gorillafart's Avatar
what are you trying to accomplish? cuz at this point, you cannot sand and buff that.
it will NEED to be repainted.
simply follow the steps that has been covered over and over on this paint and body section
sand, primer, block, (maybe primer again if need be), block, paint, clear.
Old Apr 19, 2013 | 03:16 PM
Jordan.F's Avatar
Yes, Its about to be repainted but I was just trying and wondering If I could get a better and smoother surface because atm its rough because the clear fading
I'll juste continue to sand and then prime it etc. ty for your help
Old Apr 19, 2013 | 08:11 PM
jasoncrashtech's Avatar
am i reading this correctly ???
a coarse grain is not removable !! oem single stage paint oxidizes, it always does and has. that's why factories don't do it anymore.
if you sand paint with a sharp grit it goes through the clear and scratches the base coat. at that point it needs to be repainted to be gone.
Old Apr 20, 2013 | 07:58 AM
Jordan.F's Avatar
Yes, it will be repainted
SunshineCivic
Nov 24, 2006 07:37 PM
DJNauTicz
Feb 22, 2005 08:17 PM
tommyboy
Jan 5, 2004 11:07 PM
jg
Aug 27, 2002 07:23 PM
qtiger
Apr 24, 2002 07:09 AM
