4th gen ZC in 2000 Civic EX
Old Mar 3, 2012 | 09:17 AM
rodeoking6491's Avatar
Default 4th gen ZC in 2000 Civic EX
hey everyone first time on here trying to get help with my 4th gen zc twin cam swapped into 00 civic ex. i talked to a few people and they said to use stock harness for the car ans convert the motor to obd2 so i did this got the injectors, alt, and a dizzy adaptor. i also got ecu jumper. the car was an auto i converted to 5 speed bc my zc is 5 speed. i dont have any fuel kicking on or anything. Im very new to the honda game got this far need some info on what could be the deal. i also couldnt figure out how to do the IAVC change. i know its just removing orange wire and moving one other on plug B just can figure out how to get wires to come out of the plug? help please!! thanks
Old Mar 3, 2012 | 10:02 AM
94EG8's Avatar
Seagull Management
Default Re: 4th gen ZC in 2000 Civic EX
What distributor and ECU are you running?
Old Mar 3, 2012 | 10:09 AM
I had this swap in my 95 dx it ran great! the ecu is P06,and i have the MSD blaster ss, witch im also confused about bc in the 95 there was a 3rd wire running to the key switch from the blaster ss. on the MSD website they only say there is two wires. so im lost with this thing lol
Old Mar 3, 2012 | 10:11 AM
94EG8's Avatar
Seagull Management
Is the thermostat ground connected and clean and tight? You wont have fuel or spark if it's now.
Old Mar 3, 2012 | 10:57 AM
just checked that!! that was unhooked but i got it grounded now i have fuel just no start lol and everything on the starters hooked up. maybe the msd ignition idk ??
Old Mar 3, 2012 | 11:03 AM
94EG8's Avatar
Seagull Management
I would start there.
Old Mar 3, 2012 | 11:13 AM
for this swap do i need to change them two wires on plug B for the auto to maunual swap? and if so how do you get the wires to pull out the plug with out breaking them or cutting?
Old Mar 3, 2012 | 11:16 AM
94EG8's Avatar
Seagull Management
For the IACV? Yes. It wont affect it starting or not though, it just wont idle.
Old Mar 3, 2012 | 11:22 AM
ok thanks alot!! i found the first pic on here just not all the detail to get the wires out!! do you know off hand the stock dizzy for the 4th gen zc ? and does the white tab come the whole way out or just pop up a little ?
Old Mar 3, 2012 | 11:39 AM
Arthas's Avatar
It just pops up.
Old Mar 3, 2012 | 01:38 PM
94EG8's Avatar
Seagull Management
4th gen wont work because it's OBD0 and the trigger wheels have a different number of teeth, It needs to come from a 5th gen TD-43U.
Old Mar 4, 2012 | 10:23 AM
does anyone know what color wire is the power wire on the ignition switch in the 00 civic ex? would i be right by running the power wire from the MSD blaster ss (PN8207) to the power wire under the dash on the ignition switch? I know nothing about msd but i have power to the blaster ss have power to the starter but it just clicks in the ecu when i turn it over??
Old Mar 5, 2012 | 12:56 PM
so i called msd everything on coil and dizzy is good have power at starter it just dont click or crank over just clicks in the ecu... what else would keep this thing from starting ??
Old Mar 5, 2012 | 01:25 PM
94EG8's Avatar
Seagull Management
did you make sure the transmission is grounded? (big ground from the frame rail to transmission)
Old Mar 5, 2012 | 02:45 PM
ok so far the ground wires has been my problem. the ground to the motor, and the thrmostat, i had hooked up. so know i just run a wire from the trans any were to the frame? any other grounds that i should know about to make this run?
Old Mar 5, 2012 | 02:49 PM
94EG8's Avatar
Seagull Management
That should be it.
Old Mar 5, 2012 | 03:59 PM
BobbyRodriguez's Avatar
That title has no all the way across it! just think its hard to fit a dam d-b-k-in 00+ except the si coupe. dua
Old Mar 5, 2012 | 04:05 PM
94EG8's Avatar
Seagull Management
Haven't done any engine swaps have you? A DOHC ZC (depending on exactly which one it is) fits exactly like a D-series, same mounts, uses a D-series transmission etc. The only thing a little more complicated is the electrical situation and even that isn't exactly rocket science. Also, comparing D and B to K-series is laughable. D and B-series engines are basically interchangeable using OEM Honda mounts, electrical is more or less the same as well. The K-series on the other hand is a completely different animal.
Old Mar 6, 2012 | 07:17 AM
i know nothing about cars done this whole thing by myself and with you guys help!! the trans ground was the prob, and yeah it has to be a thick gage wire i burnt the first one up!!lol but after that she fired right up!! thanks for all the help everyone!
pabloeg8
Sep 5, 2008 05:52 AM
dozer1313
Dec 22, 2004 09:19 PM
Jmorin
Feb 10, 2004 09:38 AM
