fuel
Old Oct 10, 2002 | 09:07 AM
maverickB9's Avatar
Default fuel
I have a 92 prelude s, it has 214,000 miles. What type of fuel should I put in it. 87, 89, 93 ? Any suggestions? Likewise, is there an additive that I can buy to clean out the injectors that works well. Thanx
Old Oct 10, 2002 | 10:07 AM
planeman01's Avatar
Default Re: fuel (maverickB9)
i always run premium gas. I pay for it but i prefer it. I'm sure that any of the STP fuel system cleaning systems or injector cleaneres will work about the same.
Rick
Old Oct 10, 2002 | 12:18 PM
Mike95lude's Avatar
run 87. You will gain no performance running anything better. You could try 89, but 92 is completely unnecessary and would decrease power output if anything.
I recommend Regane complete fuel system cleaner as an injector cleaner.
Old Oct 10, 2002 | 12:25 PM
4glude's Avatar
Default Re: fuel (Mike95lude)
it says straight on the manual.. for all prelude S its 87 and for both si and si vtec is 92.
Old Oct 10, 2002 | 01:52 PM
RAB's Avatar
RAB
Default Re: fuel (4glude)
you put fuel in your car. WOW you must have some special engine if you have to put different combinations of combustilbe liquids in your tank.
I put gas in my car and so you many other people.
Old Oct 10, 2002 | 02:51 PM
LudemanDan's Avatar
Default Re: fuel (RY8127)
Wow, that last reply was kind of smart-***. But anyway...
I have a '93 S. You are wasting your money to use anything higher than 87. I ran high octane for a couple months and it didn't make a difference. However, with such high mileage as yours, you should be listening closely for pinging. If you hear an early detonation, definitely switch to 89.
As far as injector cleaner, I run it every couple months or so and it doesn't seem to have any effect. Maybe that just means my injectors are clean. I did read somewhere recently, though, that lots of injector cleaner is bad for your gaskets or something. (?)
Dan
NACvicSi
Oct 29, 2013 04:23 PM
05civicdriver
Jul 11, 2008 03:05 PM
SIXPAK GQ
Jul 22, 2007 12:00 PM
SOHC-VTEC-BB2
Jan 10, 2007 06:37 PM
Tripz
Jul 8, 2002 04:49 AM
