B18b1 Crx Wont Start..
take the main relay out and open it out, if you dont have good eye sight i'd get a magnifying glass look at the soldering points and sometimes if they have even the slightest crack or hairline crack it could be bad.. if you are any good at soldering just heat up the solder points and add some solder and it will work just fine.. thats if the main relay is even bad. there are ways to check it with a volt/ohm meter tho
I know this is a little late but it may be helpful for someone
How to test the main relay:
https://honda-tech.com/forums/honda-crx-ef-civic-1988-1991-3/checking-main-relay-pics-2535047/
https://honda-tech.com/forums/showthread.php?t=2535047
wisebear1
Dec 6, 2010 09:24 PM
