Help! Jdm Door can fit to CRX OEM DOOR PANEL?
i am plan to buy JDM Option Door to put my crx. i want to know if it can fit my OEM CRX door panel to JDM Door. let me know thanks H-T.
Do you want them for the power window option? they should fit either way but I would advise to buy the UK ones cause they had power windows for the lhd...
Anything LHD is imported there, they are RHD. You will find LHD switches in Europe, mainly in the netherlands. The doors will fit early cars with pillar-mounted belts, if you have door belts the frame is different and you will need some welding if want the door to seal.
The door belt frame isn't different. I ran a pillar-belt door on a door-belt car for a long time before switching back doors to have a seat belt again (the window got busted out, took forever to find a window)
If it's electric windows, no, you'll need a panel for the electric window switches. If not, then you have to use a '88 door panel (pillar belts).
The door-mounted belt cars have a different shape near the top because of the 2 reinforcement anchors, it will leak. I saw a thread before with pics of the difference, but I can't find it now.
I've never heard of jdm option doors, but your panel will fit fine. If you need electric windows i can check if i can find you a set as i live in europe
Canada, Japan, Europe and every other country in the world use pillar mounted seat belts, and the USA got them only one year, 1988. If your US model is an 88, you will be able to use your original door panels, but they would need to be modified to run power windows.
Europe is indeed a great option for door panels and switches/harness's.....i did exactly that myself. Here is what a set from a VT model
EG(6)SR
Dec 28, 2005 09:28 PM
