Suspension & Brakes Theory, alignment, spring rates....
Creaking when turning
Old Mar 2, 2012 | 12:35 PM
SharkEg's Avatar
Default Creaking when turning
I have a creaking noise that comes from the front of my car when I turn. I was told it is my rack and pinion by a guy up at a tire shop. I also heard it could be my strut bar? Well I am buying Upper Control Arms /w Ball Joints, Inner and outer tie rod ends, sway bar link kits, rack and pinion and lower control arms, any thing else you can think of I need.
Old Mar 2, 2012 | 12:42 PM
civicsmoke's Avatar
Default Re: Creaking when turning
sounds like its just your lower ball joint.
Old Mar 2, 2012 | 07:45 PM
SharkEg's Avatar
All right, Im getting ball joints with my tie rods, also the steering wheel has slack in it.
Old Mar 3, 2012 | 09:00 PM
GGMK's Avatar
If the vehicle makes a "ratcheting" noise when you steer, like a rotating, grinding noise, then it's probably one or both of your CV joints. I had this problem, and solved it by buying remanufactured ones. It's a fairly common problem, actually.
Old May 3, 2012 | 10:41 AM
SharkEg's Avatar
No, I am buying a new rack and pinion, and new cv joints. I got my tie rods, ball joints and upper control arms put in, and still a creaking sound. I couldnt allign it because my old rack and pinion was almost shot
Old May 7, 2012 | 03:49 PM
GearHeadDeals.com's Avatar
There are so many things it could be. More info is needed on how it started and details of what causes it.
Old Jun 17, 2012 | 05:01 PM
dachsundlvr2's Avatar
i have the same issue with a four door i just bought, but no one seems to know what it is exactly. did you replace rack and pinion yet? is noise still there? i am a 45 yr old mom working with my son to diagnose my 93 civic four door.
alscrx
29
Aug 10, 2021 11:23 PM
Bleakened
Mar 30, 2019 07:29 PM
William1991b
Oct 18, 2017 09:57 PM
allmotorpackage
Suspension & Brakes
Oct 24, 2007 03:09 PM
89 exi nut
Sep 21, 2004 04:19 PM
