Stupid Question about JE pistons.
Old Oct 10, 2002 | 08:41 AM
Type-ARR's Avatar
Default Stupid Question about JE pistons.
Ok guys, Im looking for some JE pistons for my R so I got to the crower website to order a set. On the site they only have 2 compressions for the Type-R, 9.0:1 and 11.5:1, sense Im turbo I want a lower compression but not as low as 9.0:1. Under the listing for GSR pistons they have the compression I want 9.8:1. So my question is will the GSR 9.8:1 @ +.020 over work in my R or do I have to get custom pistons made? I think they will work fine, but i just want to see what you guys think first because I dont want to order custom pistons if I dont have too.
Old Oct 10, 2002 | 08:53 AM
ekb18c's Avatar
Default Re: Stupid Question about JE pistons. (Type-ARR)
JE make flat top pistons @ 81mm. The flat tops will yield somewhere in the range of 10:1. If your at 81mm (stock bore) then any b series 81mm pistons will fit fine. If you get the gsr pistons @ .20 over then you will have bore out the block to .20 over then you will be at 81.5 mm.
You can find 10:1 comp 81mm pistons from JE.
Old Oct 10, 2002 | 09:06 AM
Type-ARR's Avatar
Default Re: Stupid Question about JE pistons. (ekb18c)
Ok, man thanks, I was going to either sleeve to 81.5mm or bore but any how thanks for the info.
Old Oct 10, 2002 | 10:22 AM
Hooch'n's Avatar
JE has some real nice set-ups with their piston applications........I looked at the N/A pistons for my car.... . Good luck with mods.
90CB7EX
K Series
Nov 16, 2016 07:20 PM
qazaq
Feb 22, 2007 06:49 AM
masteryoda10
Jan 30, 2006 04:30 AM
TurboT
Nov 28, 2001 01:42 PM
