Suspension & Brakes Theory, alignment, spring rates....
CX vs. SiR front Disc Brakes
Old Mar 1, 2012 | 11:32 PM
abs0Lut's Avatar
Default CX vs. SiR front Disc Brakes
Hey I am wondering what the difference between the 2 disc brakes on a 5th gen(EG6) Civic are. I would assume the SiR utilizes a bigger rotor but I have searched and searched and can't find the answer. If they discs are the same size I wouldn't worry about swapping the knuckles out(obviously). Thanks in advance!
Old Mar 2, 2012 | 06:20 AM
phunhaus's Avatar
Default Re: CX vs. SiR front Disc Brakes
SiR = DC2 sized. You would need to swap the knuckles.
Old Mar 2, 2012 | 08:57 AM
abs0Lut's Avatar
Alright, thanks man!
Old Mar 2, 2012 | 01:03 PM
abs0Lut's Avatar
how about stainless steel lines? is it safe to assume dc2 lines will work on a cx chassis with sir discs?
Old Mar 4, 2012 | 03:28 PM
abs0Lut's Avatar
Old Mar 5, 2012 | 06:28 AM
phunhaus's Avatar
Yes.
Old Mar 5, 2012 | 10:33 AM
WhiteSlips's Avatar
US 92-95 Civic front brake lines are the same as 94-97 Integra and EG6 SIR front brake lines. JDM EG6 SIR rear brake lines are the same as 94-00 Integra rear brake lines. If you convert from rear drums to SIR or Integra rear disks you will need Integra rear brake lines.
Hope that helps....
dc5itracer
Jun 30, 2011 01:30 PM
BrayzieEF9
22
Apr 19, 2010 05:53 PM
trrbl1bmx
Jun 30, 2006 08:33 PM
vtecb20coupe
Jan 21, 2004 10:32 AM
virginia_dude
Jan 16, 2004 05:11 PM
