My radio station doesnt work..
Old Mar 1, 2012 | 01:34 PM
RiddimzCD5's Avatar
Default My radio station doesnt work..
I HAVE A 96 ACCORD (CD5) AND ON MY RADIO I PUT THE F.M STATIONS ALL I HEAR IS STATIC.. TRIED LOOKING FOR THE ANTENNA BUT NO LUCK.. I THINK IT MIGHT BE THE FUSE BUT CANT FIND IT EITHER.. CAN ANYONE HELP ME HERE.. IM LIKE A NEWBIE AT THE MOMENT.. LOST..
Old Mar 2, 2012 | 04:57 AM
RiddimzCD5's Avatar
Default Re: My radio station doesnt work..
anyone???
Old Mar 2, 2012 | 05:19 AM
civicvp's Avatar
Sounds like your antenna connection is missing.
Can you pull the HU out far enough to see or feel if the coax is connected? Did it work before? What changed from the time it worked until now?
Old Mar 2, 2012 | 05:27 AM
accordache's Avatar
i believe there is no fuse invovled in this if all the other components of the radio are functioning. it is definitely the antenna, check if your car's antenna is tightly screwed to the pole or check behind the radio for the antenna connection.. it is usually just a connection similar to an rca male terminal, just a bit larger.
Old Mar 2, 2012 | 06:06 AM
RiddimzCD5's Avatar
i cant find the antenna.. where would it be??
Old Mar 2, 2012 | 07:16 AM
GhostAccord's Avatar
If I remember correctly the antenna in some of the 96 Accords is located in the rear window. If you have had the glass replaced with aftermarket that could be why. There should be a connector located at the rear under the head liner. Check that connection and also check that the antenna coax cable is still inserted to the back of the head unit. Most times as long as the coax is inserted into the head unit you should get reception.
Old Mar 2, 2012 | 07:59 AM
RiddimzCD5's Avatar
ya you might be right.. back window.. i was told the same thing.. what should the connector look like and what you mean the coax cable..? where the head unit...
Old Mar 2, 2012 | 08:31 AM
It would be the only connector at the rear of the head liner. If I remember correctly it is a black single wire connector.
The head unit is your actual stereo unit. If you pull it out you should see a thick shielded black wire that looks like old TV cable. That is a coax cable and it should be connected to the radio.
Old Mar 2, 2012 | 09:12 AM
RiddimzCD5's Avatar
thanks ima go check this out right now and ill update in a second.. m=
Old Mar 2, 2012 | 10:29 AM
Arthas's Avatar
I would first check if its even connected on the radio. Thats an easy fix.
Old Mar 3, 2012 | 03:46 AM
RiddimzCD5's Avatar
thanks i fixed the problem.. i had a system and a radio put in and they forgot to put the connector to the radio.. thought they plugged it in cause they installed a whole system and radio.. i thought it was my antenna.. but thanks i found the problem and fixed it..
97honda_accord
Mar 29, 2015 08:24 PM
DC5_lov3r
Nov 26, 2007 05:18 PM
sony224422
Jun 15, 2006 05:22 PM
geminis2k
Dec 1, 2003 10:53 PM
nwarp
Audio / Security / Video
Mar 12, 2003 08:05 PM
