ZC with ZC ECU
Old Oct 10, 2002 | 07:59 AM
muskrat's Avatar
Default ZC with ZC ECU
I got my '89 CRX with the DOHC ZC already swapped in. Just recently I found out that it has an Si tranny and an original ZC ECU. Is this the best ECU for me to be using?
Justin D. Fender
Old Oct 10, 2002 | 08:10 AM
REDBARON's Avatar
Default Re: ZC with ZC ECU (muskrat)
Yes. The only drawback about that Ecu (if you want to call it that) is that it has a speed limiter which will only let you go to about 112mph. Other than that it's the best ecu to use for that engine since it specifically made to run it.
Old Oct 10, 2002 | 08:46 AM
1990hondaHF's Avatar
Default re: zc with zc ecu (REDBARON)
Sunny, the last time I went 112 was back in 1955. I was 75 years old then...
Really though, for regular street use I have never gotten close to that speed. Mantaining those high RPMs makes me a little nervous...what would that be with a SI trany? 6500 RPMs? No thanks you! I trust my ZC...but it IS 10 years old!
Old Oct 10, 2002 | 09:14 AM
FourthGenHatch's Avatar
Default Re: zc with zc ecu (Home audio video man)
I thought the Integra ECU was supposed to be much better.
Old Oct 10, 2002 | 10:17 AM
REDBARON's Avatar
Default Re: zc with zc ecu (FourthGenHatch)
No. The Teg ecu is better than the Si one, but it's not better than the ZC.
Old Oct 10, 2002 | 10:33 AM
muskrat's Avatar
Default Re: ZC with ZC ECU (redbaron)
That's odd. I talked to the guy who built the car, he told me that he put the ZC ECU in it. Then he sold it to his brothe who got pulled while racing, cop clocked him at a buck twenty five. Hmmm...
Justin D. Fender
Old Oct 10, 2002 | 10:39 AM
EP3_05's Avatar
It could be chipped. When I had my ZC I had a ZC ecu that i had chipped to remove the speed limiter.
Old Oct 10, 2002 | 10:57 AM
JOEBLAZE78's Avatar
Default Re: zc with zc ecu (1990hondaHF)
i whas just going 130+ last night against a mercedes compressor
Old Oct 10, 2002 | 10:58 AM
JOEBLAZE78's Avatar
best ecu for that is the intrega one better fuel maps
Old Oct 10, 2002 | 07:09 PM
Default Re: ZC with ZC ECU (91civic)
What chip did you use? Did it change the fuel maps?
deerek101
Feb 7, 2006 05:10 PM
South Bay Surfer
Feb 29, 2004 12:10 PM
stock_cx
Dec 31, 2003 10:26 AM
vtec_head
Oct 2, 2003 07:59 AM
cr-x si
Aug 6, 2002 04:03 AM
