Eliminate Main Relay
Trying to simplify wiring for a race car. I have the diagram for the Main relay infront of me right now, but dont know a whole lot about wiring.
The fuel pump is on a toggle switch already that is completly seperate from the main harness. Can i just connect the yellow/blk and the yellow/white
If i could get some help it would be appreaciated.
I am not entierly sure how the "starting input" works... But I would just tie the yellow black to an ignition switched power source... Thats all I needed to do when I bypassed mine.
I do believe I ran the "black yellow" wire coming in from the solenoids to switched power as well because it would run in a limp mode if I did not have that hooked up.
I would put the fuel pump onto some sort of ignition power switch as well, it is a sorta a pain to always have to toggle the fuel pump on and off.
katiejoy
Jul 24, 2014 11:33 AM
EusebioSam19
Nov 22, 2010 09:21 PM
g2tegsown
Audio / Security / Video
13
Aug 21, 2008 10:30 AM
jvans04
Jul 24, 2005 04:49 PM
