Buzzing Noise behind the seats, Del Sol far from home.
Old Feb 29, 2012 | 07:33 PM
78F350's Avatar
Default Buzzing Noise behind the seats, Del Sol far from home.
I'm on a road trip 500 miles from my tools and home and my Del Sol has started making a buzzing noise from about where the fuel tank sits. So far its running good and only has the sound when it's running.
Bad fuel pump?
If so, easy enough for a roadside replacement?
Anyone else have this problem?
I'm hoping to drive home in a couple days and fix it there. Just hate to have it die in the middle of Texas.
Old Mar 1, 2012 | 12:00 PM
Mitchness's Avatar
Default Re: Buzzing Noise behind the seats, Del Sol far from home.
Well if it's coming from the area of the gas tank (underneath the passenger bin) then yeah it probably is the fuel pump. Definitely not a roadside repair as you need to rip the bins out to get to it.
Is the car stumbling at all or otherwise having power issues?
Old Mar 1, 2012 | 01:00 PM
grinch559's Avatar
my del sol does the same thing and i looked it up on alldata and there is a TSB about the catalytic converter humming after the car has stopped.
Old Mar 1, 2012 | 02:16 PM
78F350's Avatar
No noise today and I had drove about 8 hours straight yesterday when it started. Probably hot and tired at 19 years old.
Just traveling local for a couple days.
Maybe get a pump before I leave San Antonio. Can't hurt to have it if I plan to replace it at home anyway.
Old Mar 1, 2012 | 03:33 PM
Red_Army's Avatar
it would be a pain but if you HAD to change it road side besides having to take out the storage bins its a pretty easy fix to do.
but hopefully you make it home before then.
Old Mar 1, 2012 | 05:17 PM
78F350's Avatar
If I do have to do it, I'm guessing tools will be Phillips, 10mm, 12mm. Except maybe the fuel fitting. Can anyone verify what size I need to get that off?
Old Mar 1, 2012 | 05:27 PM
xide_12's Avatar
you can replace the fuel pump using only a philips head screw driver, pliers, 10mm and 17mm sockets. 17mm is for the fuel line
Old Mar 1, 2012 | 06:07 PM
k3vmaster's Avatar
bad fuel pump
Old Mar 2, 2012 | 07:29 PM
grinch559's Avatar
are the fuel pumps difficult to pull out?
Old Mar 2, 2012 | 07:55 PM
Alfa Q the 2nd's Avatar
Here is a DIY
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-del-sol-rear-compartment-fuel-pump-removal-%5B26-pics%5D-2775497/
tuninmlt
15
May 9, 2016 11:47 AM
h0ust0n_del_sol
Apr 6, 2011 07:40 AM
wilderness166
Oct 21, 2010 01:19 AM
hondadrvr
Nov 10, 2004 09:31 PM
yellowmonkeyboy
Feb 24, 2004 01:05 AM
