A6 block z6 head compression number problem
Well I had my cylinder head rebuilt and after installing it ran fine for a few hours then it sat for a month. And it would not start at all and once started it missed horribly. Numbers on compression came up as follows 1,2,3,4 185,0,190,205 cylinder 2 ended up having a bent valve even though it had been rebuilt and entrant valves had been replaced. Well I got another valve lapped it in and put cylinder head back on and did not replace head gasket seeing how it was only used for a few hours now the compression came up as follows 1,2,3,4 185,180,150,205 does anyone think that could just simply be me being a tight *** and not replacing the gasket it is a metal 3 layer btw
also, what the hell are you asking exactly?
^ this does not make sense.
Yeah, reusing a H.G. is a no-no.....you could've spent the extra money on it while you had the head off again for the valve and installed a new one on with the reinstallation. Unfortunately, you're gonna have to take it off again for a new H.G. It's atleast you're main problem....no telling if there's any other lingering situations.
I was wondering if it would cause the different compression numbers soniol try throwing another gasket on it and get an oem Honda one instead of the felpro one and just get it done right this time just wasn't sure since it were metal if it woul cause the compression check issue
SolScifen
18
Jan 7, 2012 04:49 PM
tundra2000
Apr 29, 2011 08:35 PM
Ivan_JDM_hatch
12
Jul 13, 2007 06:44 PM
NACvicSi
10
Oct 19, 2005 01:31 PM
