Del sol si shiftlinkage.. No reverse?
Old Feb 29, 2012 | 12:17 PM
ricanxplaya's Avatar
Default Del sol si shiftlinkage.. No reverse?
Hey I just got a del sol vtec shiftlinkage from some one on here and I installed it on my del sol w b16a swap, all stock. The linkage fit in right perfectly. The problem I can't figure out is why it won't move in reverse? I put in reverse or so it seems, it moves forward. I'm trying to shift in reverse. Could the linkage be wrong in length or anyhow?
Old Feb 29, 2012 | 02:11 PM
24TEN's Avatar
PHANTOM MENACE
Default Re: Del sol si shiftlinkage.. No reverse?
Was your car working with reverse prior to the installation of this new shift linkage?
Old Feb 29, 2012 | 03:02 PM
NVturbo's Avatar
O.G. triple O.G.
If you're able to shift into all 5 gears except reverse, the tranny might be messed up with the reverse gearing.
Old Mar 1, 2012 | 06:02 AM
Red_Army's Avatar
SI shift linkage is not VTEC shift linkage. just so you know.
if you bought SI its for a d16.
but as asked before did it work prior to the install?
Old Mar 1, 2012 | 07:14 AM
DelSol-B18's Avatar
It's something with your trans
Old Mar 1, 2012 | 07:38 AM
NVturbo's Avatar
O.G. triple O.G.
I think he did get the B16/DOHC VTEC shift linkage. I'm still leaning towards a bad transmission.
turbodelsolb16a2
Jul 28, 2013 11:37 PM
b16delsolnewb
Apr 1, 2008 05:31 PM
turbodelsol3
Mar 9, 2007 11:57 PM
teawoboba
Jun 3, 2004 06:44 AM
b18bcivic
May 27, 2004 08:54 AM
