d16a6 into a 98 dx?
Old Feb 29, 2012 | 12:11 AM
gsr_b20b's Avatar
Default will a d16y7 oil pump fit a d16a6 block?
hey guys currently i have a d16y7(with a z6 intake manifold swap) in my 98 dx coupe. Its only got about 200,000km on it, but i have a connecting rod knock and its blown its second headgasket since ive owned it. Its time to move on. I can get my hands on 2 d16a6's for next to no cost at all and im getting one to build and one to just throw in for the time being. The one im building plans to have a z6 head, arp headstuds, cometic headgasket, for a small turbo build i have pieced together.
But my question is, i know obviously the intake manifold and header will bolt directly on. But will the obd2a distributor bolt onto the a6 head? also will the sensors under the distributor be able to plug into my factory obd2a engine harness? Anything else that might not work?
Thanks for the help
UPDATE:
new question is, will the y7 oil pump fit onto the d16a6 block? so i can use the crank sensor?
Old Feb 29, 2012 | 07:01 AM
flmzero13's Avatar
Default Re: d16a6 into a 98 dx?
good question i bet someone is bound to write back? anyone?
Old Feb 29, 2012 | 07:05 AM
bradley's Avatar
the dizzy will work, and you can use the sensors. But you WILL have to convert to OBD1, your D16Y7 has a crank sensor on the gear that you can't install onto the D16A6.
Old Feb 29, 2012 | 10:17 AM
gsr_b20b's Avatar
ok if i run it without a crank sensor ill probably get a no start?
Old Feb 29, 2012 | 10:35 AM
gsr_b20b's Avatar
also i have a obd2b to obd1 conversion harness laying around, can i use this? or will i forsure have to order a obd2a to obd1?
Old Feb 29, 2012 | 10:35 PM
gsr_b20b's Avatar
okay so i got my first d16a6, now my next question, is the d16y7 oil pump interchangable with the a6 one? can i just swap the y7 one onto the a6 block so i can use the crank sensor?
Old Mar 1, 2012 | 01:07 AM
HondaPartsHero's Avatar
Technical Hero
Bypass it
http://technet.ff-squad.com/ckftrick.htm
Your fan switch for the A6 is in the back of the block. You'll have to extend the wiring to there. If you end up running a p28 ecu down the road then you won't need the CKF at all as OBD1 doesnt use it. Other that you should be good for now.
Old Mar 1, 2012 | 01:59 AM
apexi_rsx's Avatar
you actually can run a crank sensor but u have to replace the oil pump,crank sensor, lower timing gear, oil pickup and oil pan. Then u will need to plug where the dipstick goes through the oil pump. Or you could pull the dipstick tube and dip stick from a junkyard from a y7,y8, or y5 motor. I guess for some people its just more work then just getting a conversion harness and ecu. I did my z6 in my 97 civic this way so i didn't have to splice wires for the CFK trick to pass the sensor to pass emissions
Old Mar 1, 2012 | 10:03 AM
gsr_b20b's Avatar
Originally Posted by HondaPartsHero
Bypass it
thank you very much this helps alot
Alicali
Aug 19, 2017 11:15 PM
Mike K
Aug 7, 2006 05:33 PM
Infinite Auto
Jan 12, 2004 09:05 AM
CRXracer88
Dec 22, 2003 07:59 PM
