B series waterpump replacement.
Old Feb 28, 2012 | 03:25 PM
DelSlowb16's Avatar
Icon2 B series waterpump replacement.
Is there an easy way to replace a waterpump without having to remove the engine. Its a b16 in a del sol I replace everything except the waterpump gasket and it is leaking.
Old Feb 28, 2012 | 04:13 PM
LSVTAK_EK's Avatar
Default Re: B series waterpump replacement.
Check the FAQ section. It can be done without removing the engine!
Old Feb 28, 2012 | 04:14 PM
civicjunkie17's Avatar
Kinda, To do it you would need to remove the harmonic balancer to take the lower timing cover off. Then after the cover is off loosen the belt tension, and take the 5 waterpump bolts out? Be careful when taking the bolts out there's 2 long ones and 3 short ones. Make sure you remember where they go.
Old Feb 28, 2012 | 04:48 PM
DelSlowb16's Avatar
thanks guys and yeah my cover is off.
mem94043
May 16, 2011 12:28 PM
Kuhniee
Mar 11, 2010 12:15 PM
GrnZ
Mar 25, 2008 06:49 AM
nbcivic
Feb 6, 2006 05:09 PM
hOndafienD 04
Jun 1, 2004 06:27 PM
