need camber kit for my 96 accord
ok guys anyone have any help here just put the new tires on my car and im trying to prolong the life i was wondering what you guys have on your cars for camber kits....PLEASE HELP!!!!!!!!!
ok will do the alignment. i thought they couldnt do anything to help the camber on the 96 accords with out a camber kit? sry kinda new to the whole lowered car scene but i have gone through 1 set of brand new front tires and 4 old used tires cords showing on all 6 tires.
but thanks willl go for an alignment sometime this week and see where i am after that
ingalls, spc, or eibach. i have always installed my kit then had alignment to get my camber adjusted at same time, although its a friend that does is, have no idea if regular alignment shops will adjust the camber for you also.
I have been down the same road as you with the camber and burning tires fast. Yea, get that alignment and we can suggest what road you would like to take. Personally, I use the ingalls anchor kit on the upper arms and the washer trick on the back with a mod to the chassis to clear the upper fender well.
SPC products are top notch.
Get some camber kits and adjust the camber yourself. just dont make it way too cambered, just slightly and have them adjust your TOE front out a little and TOE rear to in a little.
0 toe does not always solve camber wear issues and this setting has horrible driving feedback.
Remember this
Camber wears tires
Toe EATS tires.
OdysseyHF
Nov 29, 2003 07:25 AM
